PRV Audio 69FR250-4 6"x 9" Full-Range Speaker 4 Ohm
PRV Audio's 69FR250-4 6" x 9" full-range driver uses a naturally damped paper cone and optimized whizzer cone to produce response from 85 to 20,000 Hz. This driver makes it easy to add midrange and high frequencies to any system.
- 1.5" voice coil with ample venting to handle up to 125 watts RMS
- 90 dB sensitivity for high output capability
- Naturally damped paper cone provides smooth response
- True full-range response eliminates the need for a crossover in the sensitive midrange band
- Recommended for use with an 85 Hz @ 12 dB/octave high pass crossover
Your Price: $69.91
MSRP: $87.39
Only 4 In Stock
We'll send you an email when PRV Audio 69FR250-4 6"x 9" Full-Range Speaker 4 Ohm is back in stock or available for preorder.
