  • PRV Audio 4MR60-NDY-4 4" Neodymium Midrange Speaker 4 Ohms
PRV AudioPart # 294-3402
Model: 4MR60-NDY-4
Introducing the PRV 4MR60NDY-4, a compact 4-inch neodymium full-range loudspeaker designed to provide expansive frequency coverage and a consistently level midrange response.
  • Very low profile loudspeaker, fit it in tight spots easily
  • Strong neodymium motor, increases efficiency on a compact design
  • Broad 90-20,000 Hz frequency range for ultimate flexibility
Your Price: $39.91
Save $9.98 (20%)
5 In Stock
We'll send you an email when PRV Audio 4MR60-NDY-4 4" Neodymium Midrange Speaker 4 Ohms is back in stock or available for preorder.
Order in the next 15 hr 36 min to ship today. Details
Introducing the PRV 4MR60NDY-4, a compact 4-inch neodymium full-range loudspeaker designed to provide expansive frequency coverage and a consistently level midrange response. This characteristic ensures the pristine delivery of vocals and instruments, making it an excellent choice for optimal audio performance in portable speaker systems, line arrays, and even car audio setups where constraints of weight and space are key considerations in the project. Remarkably efficient with a 91 dB rating and capable of handling up to 60 watts of power, this driver achieves an impressive output that defies its compact size.
Boasting an exceptional frequency response spanning from 90 to 20,000Hz, this speaker emerges as a versatile "Master of All Trades," seamlessly delivering high-fidelity sound whether employed as a midbass, midrange, or full-range speaker.
BrandPRV Audio
Model4MR60-NDY-4
Part Number294-3402
UPC810075522938
Weight0.6
Nominal Diameter4"
Power Handling (RMS)60 Watts
Power Handling (MAX)120 Watts
Frequency Response90 to 20,000Hz
Sensitivity91dB 2.83V/1m
Voice Coil Diameter0.75"
Resonant Frequency (Fs)95.6Hz
DC Resistance (Re)3.3Ω
Voice Coil Inductance (Le)0.051mH
Mechanical Q (Qms)4.74
Electromagnetic Q (Qes)1.04
Total Q (Qts)0.85
Compliance Equivalent Volume (Vas)1ft³
Mechanical Compliance of Suspension (Cms)0.664mm/N
BL Product (BL)2.82T·m
Diaphragm Mass Inc. Airload (Mms)4.17g
Maximum Linear Excursion (Xmax)1.4mm
Surface Area of Cone (Sd)55.4cm²
Voice Coil Wire MaterialCCA
Magnet MaterialNeodymium
Overall Outside Diameter4.16"
Baffle Cutout Diameter3.64"
Depth1.75"
Sealed Volume0.158ft³
Sealed F3102.8Hz
Vented Volume0.44ft³
Vented F349.18Hz
