  • PRV Audio 12MB2000FT Forte Series 12" Midbass Speaker 8 Ohm
PRV AudioPart # 294-2769
Model: 12MB2000FT
The PRV Audio 12MB2000FT is a 12″ mid-bass speaker built for high-output custom door panels. It’s designed to deliver linear vocal clarity and strong punch down to around 80 Hz without demanding large enclosures. This model is part of the Forte Series, where power handling and low distortion are priorities.
  • 2000 W continuous program power rating for high acoustic output
  • High BL factor and Xmax for strong low-frequency movement and output
  • Unmatched linear mid-bass response with high 99 dB sensitivity
  • Paper cone with high-strength composition for improved midrange linearity
  • Double roll surround for controlled cone travel at high excursion
  • Rigid cast aluminum frame with side forced cooling to help keep voice coil cool under load
Your Price: $199.91
Save $49.98 (20%)
We'll send you an email when PRV Audio 12MB2000FT Forte Series 12" Midbass Speaker 8 Ohm is back in stock or available for preorder.
The PRV 12MB2000FT delivers an excellent linear response with controlled output down to 80 Hz, making it a strong choice for two-way cabinet systems that demand high BL motor strength and impactful midbass performance.
It is a notable addition to the Forte Series, where increased power handling and reduced distortion in the mid and low-mid bass range are key design goals.
Its strong midbass output remains tightly controlled to 80 Hz due to its high Xmax, making it well suited for ported PA cabinets that require solid BL force and midbass punch, as well as ported stuntwall enclosures used in car audio applications.
  • 2000 watt continuous program RMS rating supports very high acoustic output
  • High BL strength and large Xmax deliver powerful low frequency performance
  • Exceptionally linear response provides accurate music reproduction across a wide frequency range with 99 dB sensitivity
  • 12″ pro audio midbass driver built for high power low frequency use in custom stuntwalls or ported enclosures
Featuring a paper cone made from a specially formulated high strength paper pulp designed to deliver maximum linearity throughout the midrange frequencies. It also incorporates a dedicated cone treatment that enhances the damping characteristics of the moving assembly, resulting in improved vocal reproduction.
This midbass is built to withstand years of demanding professional use.
A double roll surround maintains linear cone motion at high excursion, delivering excellent vocal clarity and detail while producing a powerful, dynamic midbass response.
The specially engineered rigid cast aluminum frame includes side forced cooling openings that promote airflow to help cool the voice coil.
Its large ferrite motor provides ample room for the tall voice coil to move at high excursion, allowing the cone to reach approximately 1.50″ peak-to-peak travel for powerful, hard-hitting output.
Thanks to its silicone spider, this speaker is able to handle high excursion signals without sacrificing sound quality. This allows it to produce strong low frequency output while preserving vocal clarity and definition.
The suspension system provides excellent control during large excursions and can withstand short bursts of extreme power without damage, carrying over proven technology from previous models.
Recommended Amplifier configurations and crossover points:
2 Speakers – 1x QS5000 at 2 Ohm, 2 speakers in parallel
4 Speakers – 1x QS7000 at 2 Ohm, 4 speakers in parallel
8 Speakers – 1x QS16000 at 1 Ohm, 8 speakers in parallel
Recommended HPF using PRV Digital Signal Processor DSP when using up to 2000 Watts RMS musical power ( without clipping )
85 Hz at 12 dB per octave filter Crossover / BT12
80 Hz at 18 dB per octave filter Crossover / BT18
If you have compression drivers on your system the recommended LPF is 1,800Hz at 18 dB per octave filter Crossover / BT18 but you may set it lower to blend in better depending on the other components in your system.
PRV's recommendation for custom box design is this compact and efficient design that allows you to make multiple boxes in a trunk. It is possible to fit up to 12 speakers inside a large SUV, creating the ultimate stuntwall.
BrandPRV Audio
Model12MB2000FT
Part Number294-2769
UPC810075520965
Weight18.7
