  • PRV Audio 10W650A-4 Alto Series 10" Pro Woofer 4 Ohm
PRV AudioPart # 294-2894
Model: 10W650A-4
The PRV Audio 10W650A-4 is a 10" professional woofer from the Alto Series, designed for high-output applications requiring natural, dynamic sound. With a program power rating of 650W and a sensitivity of 97 dB, it delivers robust performance suitable for various systems, including two-way and three-way systems, as well as bass guitar and guitar speakers.
  • Vented pole piece keeps the 2.5" VC cool for continuous high power handling
  • Non-pressed paper cone with woven-cloth dustcap offers durability and clarity
  • Stamped steel frame provides structural integrity and reduces resonance
  • Frequency response of 75–5,500 Hz covers critical low to midrange frequencies
  • Suitable for vented and sealed enclosures
PRV Audio 10MR650A-4 Alto Series 10" Midrange Driver 4 Ohm
Price: $85.91Part # 294-3542
Your Price: $77.91
MSRP: $97.39
Save $19.48 (20%)
5 In Stock
We'll send you an email when PRV Audio 10W650A-4 Alto Series 10" Pro Woofer 4 Ohm is back in stock or available for preorder.
High fidelity meets high output in PRV Audio's ALTO Series Woofers. Audio professionals and seasoned musicians know that tone is essential to a great performance, whether on stage or in the studio. That’s why PRV Audio’s Alto Series woofers are meticulously engineered and voiced to deliver smooth, natural sound with dynamic character.
To achieve the desired tone, a specialized composite cone made from non-pressed paper (visible from the rear) is used to minimize break-up and provide a smooth response. A distinctive woven-cloth dustcap enhances sensitivity by lowering moving mass and also aids in cooling the voice coil.
Alto Series woofers perform exceptionally in both sealed and vented enclosures, whether used as woofers in two-way systems, midrange drivers in three-way setups, or even in bass guitar and guitar speaker applications. Step up to the PRV Audio ALTO Series… You’ll be glad you did!
  • 650 Watts program RMS power delivers strong acoustical output
  • 4 Ohm impedance makes this a great option for car audio
  • Handles extreme output levels with 97 dB sensitivity
  • Voice Coil Diameter: 2.5″
General Specifications
  • Nominal Diameter: 10″ (254 mm)
  • Nominal impedance: 4 Ohms
  • Rated AES Power Handling (RMS): 325 Watts
  • Program Power: 650 Watts
  • Sensitivity 2.83V at 1m: 97 dB
  • Recommended Hi Pass Crossover:** 150 Hz**
  • **For Full Power Handling **12db Per Octave Crossover
  • Frequency Response at -10dB: 75 – 5,500 Hz
  • Voice Coil Diameter: 2.5″ (65.5 mm)
  • Voice Coil Wire: CCAW
  • Voice Coil Winding Depth: 13.0 mm
  • Former Material: Kapton
  • Magnetic Gap Depth: 10.0 mm
  • Frame Material: Stamped Steel
  • Overall Diameter: 10.10” (257 mm)
  • Front Mount Baffle Cutout: 9.25” ( 235 mm)
  • Mounting Depth: 4.3” (110 mm)
  • Overall Depth: 4.72” (120 mm)
  • Net Weight: 10.49 Lbs (4.75 kg)
BrandPRV Audio
Model10W650A-4
Part Number294-2894
UPC602938021845
Weight12.7
Nominal Diameter10"
Power Handling (RMS)325 Watts
Power Handling (MAX)650 Watts
Frequency Response75 to 5,500Hz
Sensitivity97dB 2.83V/1m
Voice Coil Diameter2.5"
Resonant Frequency (Fs)66.88Hz
DC Resistance (Re)3.7Ω
Voice Coil Inductance (Le)0.57mH
Mechanical Q (Qms)16.07
Electromagnetic Q (Qes)0.4
Total Q (Qts)0.39
Compliance Equivalent Volume (Vas)1.46ft³
Mechanical Compliance of Suspension (Cms)0.17mm/N
BL Product (BL)11.23T·m
Diaphragm Mass Inc. Airload (Mms)33.1g
Surface Area of Cone (Sd)415cm²
Cone MaterialPaper
Surround MaterialCloth
Voice Coil Wire MaterialCCA
Overall Outside Diameter10.1"
Baffle Cutout Diameter9.25"
Depth4.72"
Sealed Volume0.5ft³
Sealed F3135.8Hz
Vented Volume1.25ft³
Vented F370.2Hz
