  • PKCELL 3.7V 2000mAh Li-Polymer Rechargeable Battery 803860 with JST XH-2.54 Connector
CLEARANCE PKCELL 3.7V 2000mAh Li-Polymer Rechargeable Battery 803860 with JST XH-2.54 Connector
PKCELLPart # 142-113
Model: 142-113
Replace or add a Lithium Polymer battery to your next 4 VDC project. The slim size and 2,000mAh rating enables it to fit into small projects that demand high current.
  • Includes a plug-n-play JST type XH 2.54 connector
  • PCM over/under charge protection built-in for safety
  • Only 0.31" thick enables it to fit into smaller projects where space is limited
  • 2000mAh rating for high current projects
  • Long standby time between charges
CLEARANCE $3.18
135 In Stock
We'll send you an email when PKCELL 3.7V 2000mAh Li-Polymer Rechargeable Battery 803860 with JST XH-2.54 Connector is back in stock or available for preorder.
Why throw away expensive electronics when the battery dies? This Lithium Polymer battery replaces batteries in various types of electronic products. You will find it in many portable Bluetooth speakers, media players, smartphones and other rechargeable devices. Its 2000mAh rating enables it to hold up longer in these types of high current products.
Use this battery in your next 4-5 VDC portable project. Its size enables it to fit into small portable Bluetooth speaker projects that have up to 10W of power output, or build a small portable 10W amplifier to hook to small bookshelf speakers. The JST type PH 2.0 connector is common on many small amplifier boards. Make sue you observe the polarity before plugging the battery into any sockets. This battery also powers many Raspberry Pi and Arduino projects. Recharge the battery with a 5 VDC power adapter. Its over/under charge circuit protects the battery from being over charged.
Note: Observe the sockets polarity before plugging this battery into it.
Specifications: • Dimensions without leads: 1.5" H x 2.4" W x 0.31" D • Leads: 3.5" • Maximum voltage output: 4.2 VDC • Current rating: 2000mAh • Battery type: Lithium Polymer(LiPo) • Plug type: JST XH 2.54.
BrandPKCELL
Model142-113
Part Number142-113
UPC848864079523
Weight0.06
TechnologyLi-Polymer
Voltage3.7V
