  • Outdoor RGB LED Light Strip Controller with RF Remote
CLEARANCE Outdoor RGB LED Light Strip Controller with RF Remote
Parts ExpressPart # 073-144
Safely leave this controller outside year around and use the RF remote to change LED light strip sequences from indoors. Also works great to control marine RGB LED lighting.
  • Accepts 12 or 24 VDC input for versatility
  • Powers 12 or 24 VDC RGB LED light strips (input has to match output required voltage)
  • Safe and dependable outdoor lighting control
  • Completely sealed controller board for true weather resistance outdoor/off-road mounting
CLEARANCE $4.50
Save $17.49 (80%)
91 In Stock
We'll send you an email when Outdoor RGB LED Light Strip Controller with RF Remote is back in stock or available for preorder.
Order in the next 2 hr 29 min to ship today. Details
Exposed components never hold up to true outdoor environments. They may work short term, but then they have to be replaced. This LED controller's internal board is completely sealed to prevent moisture from damaging its components. Conformal coating only puts a thin see-through layer over the board and components. The board's thick UV resistant coating enables the LED controller to work outdoors or on boats year around without having to replace or take down during extreme weather conditions.
The outdoor controller comes with an RF remote that enables you to control your RGB LED light strips from the comfort of indoors. Change patterns, speed, dim, or just turn the light strip on/off without having direct line-of-sight with the controller. Avoid installing the controller in a metal enclosure which will greatly reduce the wireless range of the remote. The remote includes a 12 VDC 23A alkaline battery.
Part Number073-144
UPC848864053349
Weight0.45
