  • Mean Well MW LPV-60-12 12V 5A Water Resistant Power Supply AC Adapter IP67 Wire Leads
Mean WellPart # 320-3146
Model: LPV-60-12
This 12 volt DC, 5 amp regulated power supply is capable of up to 60 watts of power in nearly any environment due to its IP67 water-resistant design.
  • IP67 rated chassis for use in wet environments
  • 12 VDC regulated output with 5A current capacity
  • Overload, over voltage, and over temperature protection built-in
  • Perfect for use with up to 5 meters of SMD 5050 or SMD 3528 LED lighting strips
  • World compatible AC input
Your Price: $24.98
MSRP: $37.99
Save $13.01 (34%)
We'll send you an email when Mean Well MW LPV-60-12 12V 5A Water Resistant Power Supply AC Adapter IP67 Wire Leads is back in stock or available for preorder.
Order in the next 14 hr 49 min to ship today. Details
This switching power supply is ideally suited for use with LED lighting. With a regulated output of 12 volts DC, and current capacity of 5 amps, this power supply is the perfect partner for up to five meters of SMD 5050 or SMD 3528 LED lighting strips. The fully encapsulated IP67-rated case allows this power supply in nearly any environment due to its dust-free design and ability to be immersed in water up to 1 meter.
It also works with water resistant audio amplifiers that handle 12 VDC like marine amps and the Lepai LWP-250.
Power input is world compatible and able to work with anywhere from 100 to 240 volts AC input. Each power supply is 100% full load burn-in tested and can handle up to a 300 VAC surge for 5 seconds. Two mounting tabs and 23" long input and output leads facilitate permanent mounting. Edison style power cord required and sold separately. CE rated design.
Specifications: • Input power: 100-240 VAC, 47-63 Hz • Output power: 12 V, 5A • Working temperature: -22° F~158° F • Dimensions: 6.4" L x 1.67" W x 1.26" H.
BrandMean Well
ModelLPV-60-12
Part Number320-3146
UPC848864002651
Weight0.88
DC Output Voltage12V
Input Voltage100~240 VAC
