  • Outdoor IP68 Waterproof PG9 Plastic Cable Glands/Connectors for OD Cables 4-8mm Black 10-Pack
Parts ExpressPart # 320-4009
Protect your outdoor electrical DIY projects with these PG9 size waterproof cable gland feed through connectors. The UV resistant rubber gaskets and nylon plastic connector make them perfect for preventing moisture and dust from seeping into holes from wires run into your outdoor utility boxes.
  • UV resistant rubber gaskets and high-quality nylon body and cap insure long lasting waterproof performance
  • Click down tightening cap prevents wires from loosening over time
  • Accepts cables with outer diameter 5/32" to 5/16" (4 to 8 mm) for adaptability
  • Fits in standard 5/8" (15 mm) hole
  • Installs in boxes up to 5/16" (9 mm) thick
Your Price: $3.69
MSRP: $6.99
Save $3.30 (47%)
We'll send you an email when Outdoor IP68 Waterproof PG9 Plastic Cable Glands/Connectors for OD Cables 4-8mm Black 10-Pack is back in stock or available for preorder.
Order in the next 4 hr 1 min to ship today. Details
Cables Pass Through, But Water Doesn't
Are you looking for a reliable solution to protect your outdoor electrical DIY projects? Look no further than these PG9 size waterproof cable gland feed through connectors. Designed with your needs in mind, these connectors are the perfect choice for preventing moisture and dust from seeping into holes where wires enter into outdoor utility boxes.
The key feature of these connectors is the UV resistant rubber gaskets, which provides a secure seal and prevents any water from infiltrating your outdoor utility box. Whether it's rain, moisture, or heavy splashes, these connectors are built to keep internal wiring and electrical components completely dry and well-protected for years to come. No more worries about short circuits or damage caused by water seeping into your box!
But that's not all – the high-quality nylon plastic connectors also boast excellent UV ray resistance, ensuring that they can withstand prolonged exposure to sunlight without deteriorating. This means that even in scorching summer heat, your connectors and rubber gaskets will retain their integrity, making them the ideal choice for any outdoor setting.
Installing these connectors is a breeze – simply attach them to a 5/8" hole in your utility box and thread the cables through the PG9 size opening. The PG9 size design seals around 4-8 mm round cables. The internal rubber gasket shrinks around the cable as you tighten the cap. The cap clicks as you tighten to prevent it from loosening over time. This secure fit ensures that your cables stay in place and are properly sealed. With these connectors, you'll have your cables installed and outdoor utility box properly sealed in no time.
So, why compromise the safety of electrical components in your outdoor wiring utility box when you can have the best protection with our PG9 size waterproof cable gland feed through connectors? Don't let water damage or UV rays jeopardize the functionality of your outdoor DIY audio projects. Upgrade to our reliable and durable connectors today and enjoy peace of mind in knowing that electrical components and exposed wires in your outdoor utility box are safeguarded against all the elements. Check out our PG13.5 and PG19 cable glands for larger outer diameter cables.
Note: Click down tightening cap makes it hard to unscrew if needed.
Specifications: • Cable gland size: PG9 • Cable outer diameter accepted: 5/32" to 5/16" (4 to 8 mm) • Hole size needed: 5/8" (15 mm) Max • Inside nut: 7/8" (22 mm) • Outside nut and cap hex size: 3/4" (19 mm) • Outer nut height: 7/32" (5.5 mm) • Inner nut height: 3/16" (4.6 mm) • Cap height: 9/16" (14.5 mm) • Total body length without cap: 1-5/32" (29.1 mm) • Inner thread: 5/16" L x 19/32" Dia. (8 x 15 mm)  • Outer shaft: 5/8" L x 5/8" Dia. (15.5 x 15.5 mm) with 5/16" (9 mm) long thread.
Part Number320-4009
UPC848864074481
Weight0.15
