OPEN BOX Talent TWUH1 Wireless UHF Handheld Microphone SystemThe Talent TWUH1 wireless handheld mic system allows you to move freely around your performance space while sounding great. Using a 48 kHz audio sampling rate, the TWUH1 delivers a crystal clear vocal clarity which will help your vocals be front and center whether for a presentation, live performance, or Emceeing events.
Using a simple to use, plug-and-play IR sync function, the TWUH1 is easy to get up and running. The IR sync automatically syncs the transmitter and receiver's carrier frequency without needing to worry about increasingly complicated RF management. With 16 frequencies available the TWUH1 provides you with enough carrier frequency options to ensure clean transmission signals. In addition, the wireless system features Digital ID code that helps eliminate unwanted RF interference.
Freedom of movement on stage is essential to wireless systems, the TWUH1 gives you a line-of-sight transmission range of up to 190 ft. (60 meters). With an extended transmission range and high performance sound quality, the TWUH1 is ideal for concerts, schools, clubs, and houses of worship.
Receiver specifications: • Operating frequency: UHF 918.80 - 927.80 MHz • Sampling rate: 48 kHz • Latency: 3ms • Dynamic range: >96 dB • THD: <0.2% • Frequency response: 30 - 18,000 Hz • SNR: >96 dB • Receiving sensitivity: -94 dBm • Audio output level: 400 mV unbalanced, 400 mV balanced • Power supply: 12 VDC / 1A • Dimensions: 8.07" x 4.52" x 1.45".
Transmitter Specifications: • Transmitter power: 10mW • Harmonic radiation: <-50 dBc • Range: up to 60 meters (197 ft.) • Frequency selection: IR sync • Microphone type: Dynamic • Microphone casing: Aluminum / anodic oxidation • Battery voltage: 3V (2 x 1.5V AA batteries) • Battery life: Continuous usage > 8 hours • Dimensions: 10.12".
