CLEARANCE OPEN BOX Dayton Audio RS150P-4A 6" Reference Paper Woofer 4 Ohm
Dayton Audio
Part #86-295-563
Dayton Audio
Part #86-295-563
Model: RS150P-4A
What is Open Box? Open Box items are typically display models, demos, products opened for photography or inspection, or returns that show little to no signs of use or wear. Packaging may be non-original. Open Box Guarantee Open Box products are covered by the original manufacturer's full warranty. We guarantee that the products will function or operate perfectly. What is Refurbished/Restocked? Refurbished/Restocked products may be factory authorized B stock or C stock that have been returned by customers or retailers for a variety of reasons and have been reviewed, repaired, or repackaged by the manufacturer or our in house repair department. They may have slight scratches, dents, signs of use, or other forms of cosmetic damage that do not affect usability or performance. Packaging may be non-original. Some items may be missing non-essential parts. Refurbished/Restocked Guarantee Refurbished/Restocked products are covered by a 6-month warranty. We guarantee that they will function or operate perfectly. No Risk, No Hassle All Open Box and Refurbished/Restocked products are 100% covered by the Parts Express 60 Day No Hassle Returns Policy. Order risk free and take up to 60 days to check it out. If any Open Box item does not meet your standards simply return it within 60 days for a full refund. |
View It New |
Dayton Audio Reference Series paper cone drivers combine class-leading low distortion performance with the use of a proprietary cone blend. Now with a flatter frequency response and smoother high frequency roll-off allowing for extended bandwidth and easier crossover integration.
- Now with improved frequency response for easier crossover integration
- Three-part paper composite diaphragm featuring paper, Kevlar, and glass fibers
- Low-distortion motor, 6-hole cast frame, rubber surround, and solid aluminum phase plug
- Perfect for use as a woofer, midwoofer, or dedicated midrange driver
- 90.3 dB sensitivity and 4.4 mm of excursion
