  • Neutrik XCR-5 X Series Color Coding Ring with Label Block Green
CLEARANCE Neutrik XCR-5 X Series Color Coding Ring with Label Block Green
Neutrik
Part #092-2257
Neutrik
Part #092-2257
Model: XCR-5
XCR color coding rings from Neutrik allow you to add quick and easy identification to your cables, without desoldering the existing X Series XLR connector.
  • Green color coding ring for X Series XLR connectors
  • Installs quick and easy, without desoldering
  • Identify your cables at a glance, even from a distance
CLEARANCE $0.44
MSRP: $0.99
Save $0.55 (56%)
Quantity:Qty: 1-99 $0.44/ea
Quantity:Qty: 100-249 $0.41/ea
Quantity:Qty: 250+$0.40/ea
Order in the next 4 hr 11 min to ship today. Details
31In Stock
Make your cables and connections nearly "dummy-proof" with color coding rings from Neutrik. Their X Series XLR connectors are the most ubiquitous in the world, and now you can add convenient identification to your cables without having to desolder the XLR connector. Available in many different colors, these rings can really simplify your setup and teardown, saving you valuable time and reducing confusion when more than one person is running cables.
BrandNeutrik
ModelXCR-5
Part Number092-2257
UPC848864015675
Weight0.03
