  • Neutrik NLT4MPXX STXX Series speakON 4-Pole Male Chassis Connector Metal Housing
NeutrikPart # 092-339
Model: NLT4MPXX
4-pole male chassis connector, metal housing, ¼“ flat tabs, countersunk thru holes.
The speakON STXX Series was especially designed for heavy duty amplifier-loudspeaker applications like professional touring. The extremely rugged and durable STXX Series features an all metal housing.
  • IEC 61984 certified, IEC 62368-1 compliant
  • Extremely robust metal housing and glass reinforced V-0 material insert designed for harsh and demanding environment
  • Uses precise “Quick Lock” system
  • Weatherproof built-in gasket meets IP 54 protection class in mated condition
Your Price: $8.19
Save $0.96 (10%)
161 In Stock
We'll send you an email when Neutrik NLT4MPXX STXX Series speakON 4-Pole Male Chassis Connector Metal Housing is back in stock or available for preorder.
The Neutrik STXX Series
Neutrik speakON panel mount connectors are the standard chassis connectors for loudspeaker / amplifier interconnections. They feature a unique metal locking system, making contact only once fully locked. The speakON receptacles are robust, versatile and easy to terminate.
This connector is fully compliant to the device standard IEC 62368-1, due to its component certification according to IEC 61984.
BrandNeutrik
ModelNLT4MPXX
Part Number092-339
UPC848864024325
Weight0.11
Circuit4-Pole
GenderMale
