  • Neutrik NLT4FPXX STXX Series speakON 4-Pole Female Chassis Connector Nickel
NeutrikPart # 092-341
Model: NLT4FPXX
4-pole female chassis connector, metal housing, solder contacts or ¼“ flat tabs.
The speakON STXX Series was especially designed for heavy duty amplifier-loudspeaker applications like professional touring. The extremely rugged and durable STXX Series features an all metal housing.
  • IEC 61984 certified, IEC 62368-1 compliant
  • Extremely robust metal housing and glass reinforced V-0 material insert designed for harsh and demanding environment
  • Uses precise “Quick Lock” system
  • Weatherproof built-in gasket meets IP 54 protection class in mated condition
Your Price: $12.73
Save $0.80 (6%)
35 In Stock
We'll send you an email when Neutrik NLT4FPXX STXX Series speakON 4-Pole Female Chassis Connector Nickel is back in stock or available for preorder.
Order in the next 0 hr 22 min to ship today. Details
The Neutrik STXX Series
The speakON panel mount connectors are the standard chassis connectors for loudspeaker / amplifier interconnections. They feature a unique metal locking system, making contact only once fully locked. The speakON receptacles are robust, versatile and easy to terminate.
This connector is fully compliant to the device standard IEC 62368-1, due to its component certification according to IEC 61984.
BrandNeutrik
ModelNLT4FPXX
Part Number092-341
UPC844632095740
Weight0.16
Circuit4-Pole
GenderFemale
