  • Neutrik NL4MPXX speakON Connector 4-Pole Panel Mount
NeutrikPart # 092-052
Model: NL4MPXX
4-pole chassis connector, black D-size flange, self tapping screw holes (A-screw), horizontal PCB mount.
The speakON panel mount connectors are the standard chassis connectors for loudspeaker / amplifier interconnections. They feature a unique metal locking system, making contact only once fully locked. The speakON receptacles are robust, versatile and easy to terminate.
  • IEC 61984 certified > IEC 62368-1 compliant
  • Glass reinforced V-0 materials make it extremely robust and dependable
  • Precise keyway for secure mating
  • Accurate twist lock latching system
  • Metal insert in locking area
Your Price: $2.94
Save $0.34 (10%)
539 In Stock
We'll send you an email when Neutrik NL4MPXX speakON Connector 4-Pole Panel Mount is back in stock or available for preorder.
Neutrik speakON® Chassis Connectors
The speakON panel mount connectors are the standard chassis connectors for loudspeaker / amplifier interconnections. They feature a unique metal locking system, making contact only once fully locked. The speakON receptacles are robust, versatile and easy to terminate. The chassis connectors are airtight for audio applications (leakage 30 cm3/s at 10 kPa differential pressure) unless otherwise stated.
This connector is fully compliant to the device standard IEC 62368-1, due to its component certification according to IEC 61984.
BrandNeutrik
ModelNL4MPXX
Part Number092-052
Circuit4-Pole
GenderMale
