Neutrik NE8MX etherCON RJ45 Cable Connector Carrier Nickel
RJ45 cable connector carrier for pre-assembled RJ45 plugs consists of nickel shell, bushing and boot. Packed with two cable protection elements for cable diameter up to 8 mm. Cable connector carrier does not include a RJ45 plug.
The etherCON cable connector carrier upgrades a conventional RJ45 connector to an extremely robust lockable solution.
- The RJ45 system for harsh and demanding environment
- Cable connector carrier accepts the most common RJ45 plugs (see list at downloads)
- Rugged diecast shell and unique chuck type strain relief
- Protects Ethernet connections in a variety of commercial type applications and is designed to prevent breakage of the fragile components of standard RJ45 connectors
- Flat spot on the housing for better orientation
- Allows assembly of pre-assembled conventional RJ45 cables
- Does not intermate with the CAT6 chassis connectors NE8FDY-C6 and NE8FDY-C6-B
We'll send you an email when Neutrik NE8MX etherCON RJ45 Cable Connector Carrier Nickel is back in stock or available for preorder.
