  • Neutrik NE8FBH-S etherCON B Series Shielded Panel Mount Connector Horizontal PCB
CLEARANCE Neutrik NE8FBH-S etherCON B Series Shielded Panel Mount Connector Horizontal PCB
NeutrikPart # 092-428
Model: NE8FBH-S
Fully shielded, horizontal PCB mount RJ45 receptacle, B-series cutout with latch lock, max. panel thickness 3 mm. The "Shielded etherCON" offers a closed metal housing to avoid EMI or cross talking.
The etherCON Series is a ruggedized and lockable RJ45 connector system, optimized for pro audio, video and lightning network applications. The chassis connectors are shaped to fit into standardized panels out of the entertainment industry. The B-Series offers a space saving design and a rugged metal front plate.
  • Accommodates rugged etherCON NE8MC* or any standard RJ45 plug
  • Approved latch lock system
  • Comprehensive shielding granted by completely closed metal housing
  • Improves EMC performance of appliance even in unmated condition
  • Connector is fixed onto PCB due to soldered connector housing
  • CAT5e / Class D according to TIA/EIA 568C and ISO/IEC 11801
  • Does not intermate with CAT6 cable connector NE8MC6-MO and NKE6S* cables
CLEARANCE $8.64
Save $0.55 (6%)
6 In Stock
We'll send you an email when Neutrik NE8FBH-S etherCON B Series Shielded Panel Mount Connector Horizontal PCB is back in stock or available for preorder.
Order in the next 8 hr 14 min to ship today. Details
The Neutrik etherCON® B Series
The B-Series offers a space saving design, rugged metal front plate and fully shielded versions.
Rear panel mount
Panel fastening
Self-tapping PLASTITE®* screw with thread 2.9x1.06 and of tri-rondular configuration (A-screw)
Attention! Does not intermate with CAT6 cable connector NE8MC6-MO and NKE6S* cables.
  • Ground panel connection
  • PoE type 4 class 8 (100W) acc. IEEE 802.3bt
BrandNeutrik
ModelNE8FBH-S
Part Number092-428
UPC848864076652
Weight0.01
