  • Marine Grade Locking Cigarette Lighter Plug 12 VDC
CLEARANCE Marine Grade Locking Cigarette Lighter Plug 12 VDC
Parts ExpressPart # 265-272
The locking plugs are designed to work with an interlocking receptacle. They are manufactured from corrosion resistant marine grade materials. An interconnecting system securely locks the plugs into the receptacle resulting in a positive and moisture proof connection.
  • Locks into place to prevents coming loose when traveling off road
  • Moisture proof seal works perfect for boats and ATVs
  • Two inside screw terminals for quick installation
Marinco 12VPG 12 VDC Plug
Price: $10.39Part # 265-238
See all items in Cigarette Lighter Plugs & Sockets
We'll send you an email when Marine Grade Locking Cigarette Lighter Plug 12 VDC is back in stock or available for preorder.
The locking plugs are designed to work with an interlocking receptacle. They are manufactured from corrosion resistant marine grade materials. An interconnecting system securely locks the plugs into the receptacle resulting in a positive and moisture proof connection. Perfect for boats and ATVs, which vibrate and bounce due to rough water and bumpy terrain. Simply line up the tabs on the locking plug with the arrows on the receptacle and press the plug into the receptacle until it seats. The plug is locked into place. To remove the plug, just rotate it 20 degrees and pull out. The plug features a moisture proof sealing ring and cord seal, interchangeable 3 amp fuse, and a green LED which indicates power. You must slide the rubber ring off towards the front, unscrew the tip and remove the Phillips screw to install the wires.
Both plug and receptacle will work with any standard 12V equipment, however the locking system will only work when locking plugs and receptacles are used together.
Part Number265-272
UPC844632015632
Weight0.06
