  • Marinco 12VPG 12 VDC Plug
CLEARANCE Marinco 12VPG 12 VDC Plug
MarincoPart # 265-238
Model: 12VPG
These 12 volt receptacles and plugs are manufactured from corrosion resistant marine grade materials.
CLEARANCE $10.39
MSRP: $13.99
Save $3.60 (26%)
1 In Stock
We'll send you an email when Marinco 12VPG 12 VDC Plug is back in stock or available for preorder.
Order in the next 5 hr 35 min to ship today. Details
These 12 volt receptacles and plugs are manufactured from corrosion resistant marine grade materials. Exclusive to Marinco is the unique Sealink interconnecting system that securely locks the plugs into the receptacle resulting in a positive and moisture proof connection. Perfect for boats, which vibrate and bounce due to rough water. Simply line up the tabs on the Sealink plug with the arrows on the receptacle and press the plug into the receptacle until it seats. The plug is locked into place. To remove the plug, just rotate it 20 degrees and pull out. Receptacle features a watertight sealing cap, and is easy to install. Use the supplied mounting plate for the front panel installation, or the locking ring also supplied for rear installation. Plug features a moisture proof sealing ring and cord seal, interchangeable 10 amp fuse, and LED which indicates power. Both plug and receptacle will work with any standard 12V equipment, however the Sealink system will only work when Sealink plugs and receptacles are used together. Marinco has a 5 year warraty.
BrandMarinco
Model12VPG
Part Number265-238
UPC093344304491
Weight0.1
