  • MK KIT Bookshelf Speaker Kit Pair with Knock-Down Cabinets
NEW MK KIT Bookshelf Speaker Kit Pair with Knock-Down Cabinets
Dayton AudioPart # 300-7149
Model: MK KIT Knock-Down
Modeled after the popular MK402X bookshelf speakers, Dayton Audio’s MK Kit delivers smooth, accurate sound in a compact, DIY-friendly package. Designed for builders of all skill levels, this complete 2-way speaker kit offers non-fatiguing highs, impressive bass for its size, and a frustration-free assembly process. With prewired crossovers and precision-cut enclosures, the MK Kit makes it easy to enjoy high-quality sound along with the unique satisfaction of building it yourself.
Note: The MK KIT includes everything needed to build a pair of 2-way bookshelf speakers.
  • Everything you need to build a great-sounding pair of compact 2-way bookshelf speakers
  • Smooth, accurate response inspired by the MK402X bookshelf speaker
  • Preassembled, solder-free crossover for fast, worry-free assembly
  • Compact MDF knock-down enclosure with self-aligning rabbeted joints
  • Surprising bass performance from a 4" woofer
  • Ideal for first-time DIYers and experienced builders alike
NEW $99.98
MSRP: $161.95
Save $61.97 (38%)
Order in the next 9 hr 34 min to ship today. Details
Simple Build, Big Sound
The MK KIT is designed to make building your own high-quality speakers both approachable and fun for do-it-yourselfers of every skill level. Inspired by the popular MK402X bookshelf speakers, this kit lets you assemble a proven design using carefully matched drivers, expert-tuned crossovers, and pair of precision cut knock-down enclosures. The result is a pair of speakers you build yourself that delivers the same smooth response, clean highs, and impressive bass that listeners enjoyed from the MK402X.
Every detail of the MK KIT is optimized for an enjoyable DIY experience. The precision-cut knock-down enclosures feature self-aligning rabbeted joints that simplify cabinet assembly and help ensure accurate panel alignment. The prewired, solder-free crossovers with plug-and-play connections eliminates guesswork and allows you to focus on the satisfaction of building rather than the complexity of wiring. From first glue-up to final listen, the MK KIT delivers hands-on craftsmanship backed by a carefully engineered speaker design that performs as good as it looks.
Controlled Bass and Smooth Midrange
Low frequencies are handled by the Dayton Audio TCP115-4 4″ Treated Paper Woofer, a driver well known for its impressive excursion and low-frequency capability in compact enclosures. Its low resonant frequency and smooth midrange response allow it to deliver surprisingly full bass while maintaining clarity and control through the critical vocal range. This driver is the ideal foundation for the MK KIT’s balanced sound signature.
Detailed, Non-Fatiguing Highs
High frequencies are reproduced by the Dayton Audio TD20F-4 3/4″ Soft Dome Tweeter. Despite its small size, this tweeter offers extremely flat response, wide dispersion, and low distortion thanks to its powerful neodymium motor. The result is clean, detailed treble that remains smooth and easy to listen to for long sessions, but never harsh or fatiguing.
Preassembled and Optimized Crossover
The MK KIT features a fully assembled and wired crossover network integrated into the terminal cup. Using a 3rd-order high-pass filter for the tweeter and a 2nd-order low-pass filter for the woofer, the crossover ensures each driver operates within its optimal range for cohesive, accurate sound. With solderless connectors and no loose components, final assembly is fast, clean, and beginner-friendly.
Easy Assembly, Endless Finish Options
The compact MDF knock-down enclosure is designed for easy assembly and precision cut. Rabbeted corner joints act as a built-in assembly jig, keeping panels aligned while creating strong, clean joints. The cabinet can be assembled with glue and clamped using simple masking tape, requiring only a Phillips-head screwdriver to complete the kit. Once built, the enclosure becomes a blank canvas that is perfect for paint, veneer, or custom finishes to match your décor or showcase your creativity.
Build, Listen, Enjoy
Whether you’re building your first speaker kit or looking for a compact, great-sounding DIY project, the MK KIT is a rewarding choice. Enjoy the satisfaction of assembling your own speakers, customizing their finish, and experiencing rich, balanced sound from a design engineered to perform. From desktop audio to small room listening, the MK KIT proves that great sound and a great DIY experience doesn’t have to be complicated.
Includes:
Part #:Description:Quantity:
295-415Dayton Audio TCP115-4 4" Woofer
2
275-020Dayton Audio TD20F-4 3/4" Tweeter
2
MK KIT Knock-Down Enclosure2
MK KIT Assembled Crossover
and Terminal Cup
2
MK KIT Port Tube2
MK KIT Damping Material2
081-42325-Pack #6 x 3/4" Black Screws
1
  • Design: 2-way vented bookshelf/ desktop
  • Impedance: 4 Ohms
  • Frequency Response: 60 to 20,000 Hz
  • Sensitivity: 84 dB 1W/1M
  • Crossover: 2-way, 3,300 Hz crossover point
  • Terminals: 5-way binding posts
  • Dimensions: 9.5" H x 5.75" W x 6.125"
Note: The MK KIT 2-Way Bookshelf kit comes with nearly everything needed to build a complete pair of speakers. Including knock-down enclosures, drivers, assembled crossovers and terminal cups, damping material, and screws.
ModelMK KIT Knock-Down
Part Number300-7149
UPC848791011795
Weight10.71
Cabinet Dimensions (HxWxD)9.5" x 5.75" x 6.125"
Cabinet OptionsUnfinished/Unassembled
ColorUnfinished
Input Rating4 Ohms
Speaker TypeBookshelf
Woofer Diameter4"
