  • Landscape IP54 Weatherproof Outdoor Electrical Box 7" x 12-1/2" x 5" - Black
Parts ExpressPart # 320-4005
When it comes to outdoor projects that involve AC power plugs or audio equipment, ensuring protection against the elements is essential. This water-resistant landscape utility box is a great solution to safeguard your installations while maintaining efficiency and accessibility.
  • IP54 rating protects inside electrical components from dust and moisture
  • Built-in cable entry holes enable quick installation
  • Cable holes are protected from moisture penetration by 5-layer rubber gaskets
  • Each latch has a hole for security locks
  • Built-in strain relief holds wires in place
  • Hinged lid prevents it from being misplaced
Your Price: $17.98
Save $22.01 (55%)
We'll send you an email when Landscape IP54 Weatherproof Outdoor Electrical Box 7" x 12-1/2" x 5" - Black is back in stock or available for preorder.
Easy Outdoor Audio Installations
This utility box's design withstands various weather conditions, making them an excellent investment for anyone looking to enhance their outdoor spaces. Whether you’re setting up landscape lighting, holiday lights, outdoor speakers, or other electrical devices, using a utility box can help prevent water damage, corrosion, and other environmental hazards that can compromise your equipment. Audio amplifiers have always been a concern when mounting them outside. Installers usually leave the amp inside the house and drill holes in a wall to get the speaker cables outside. This water-resistant box will relive those fears, and let you create an awesome outdoor audio experience. With a Bluetooth amplifier you wouldn't even have to open the box.
AC Plug Safety
Not only does a water-resistant utility box provide practical protection, but it also promotes safety. By neatly housing AC power plugs, you reduce the risk of accidental damage and electrical hazards. Add security locks through the holes in the latches for more safety. This thoughtful approach allows you to enjoy your outdoor areas without worrying about potential risks.
Built-in Cable Entry Holes with Rubber Gaskets
Installing cables into this outdoor enclosure is a breeze using the built-in, rubber gasket protected holes and easy-to-follow instructions. Whether you're a novice DIY enthusiasts and seasoned professionals you'll appreciate the seal these rubber gaskets provide. Two 1/2" outer holes and three 7/16" inner holes enable most AC cables through, and the five-layer gaskets prevent moisture from entering the enclosure which would damage your components. A removable top bar with four gaskets snaps down on the cables to attain that water tight seal. The box also includes a removable strain relief that helps keep the cables from moving in or out. The box's internal dimensions, 4-1/2" D x 4-1/2" H x 11" W at the widest point with the lid shut, comfortably holds outlet strips, power supplies, and small amplifiers. With a little bit of effort, you can create a safe, organized space for all your outdoor electrical needs.
Blend It In
In summary, investing in a water-resistant landscape utility box is a smart and proactive way to protect your outdoor AC power plugs and audio projects. It not only enhances the longevity of your equipment but also ensures a safer environment for you and your loved ones. The black box also adds a neat organized appearance to a bunch of AC plugs and cords to your outdoor landscaping. Embrace the possibilities, and take your outdoor projects to the next level with this valuable addition!
Specifications: • Outer total dimensions: 7" D x 5" H x 12-1/2" W at it's widest point • Inner Dimensions: 4-1/2" D x 4-1/2" H x 11" W • Rear keyhole mounting slot spacing: 8-3/4" to center • Security lock holes: 9/64" • Cable entry holes: Two 1/2" outer and three 7/16" inner.
Part Number320-4005
UPC848864077420
Weight1.46
Construction MaterialABS Plastic
