  • LaVoce DN10.17T 1" Neodymium Compression Driver 8 Ohm
CLEARANCE LaVoce DN10.17T 1" Neodymium Compression Driver 8 Ohm
LavocePart # 293-737
Model: DN10.17T
LaVoce's DN10.17T is a high-quality compression driver offering excellent efficiency and low distortion. It is a fantastic fit for use in studio monitors, stage boxes, and sound reinforcement in small to medium rooms.
  • FEM optimized motor, phase plug, and diaphragm
  • 1,200 - 18,000 Hz frequency response
  • Titanium diaphragm and suspension
  • 4-Bolt mounting
CLEARANCE $135.00
MSRP: $201.49
Save $66.49 (33%)
Only 1 In Stock
We'll send you an email when LaVoce DN10.17T 1" Neodymium Compression Driver 8 Ohm is back in stock or available for preorder.
The LaVoce DN10.17T horn driver's diaphragm is crafted from Titanium. The driver features an FEM optimized motor, phase plug, and diaphragm for optimal performance.
The LaVoce DN10.17T neodymium motor assembly effectively concentrates flux in the gap, and highest motor strength efficiency is achieved through the use of FEM (Finite Element Modeling). A voice coil manufactured with edgewound flat CCAW (Copper Clad Aluminum Wire) and wound on a fiberglass former assures great stability and thermal resistance. This driver utilizes a standard 4-bolt mounting method.
BrandLavoce
ModelDN10.17T
Part Number293-737
UPC848864057590
Weight2.1
Diaphragm MaterialTitanium
Exit Diameter1"
Mounting Type4-Bolt
Power Handling (RMS)55 Watts
