  • Parts Express Speaker L-Pad Attenuator 100W Stereo 1" Shaft 8 Ohm
Parts ExpressPart # 260-264
L-pads adjust the relative volume of drivers connected to them by placing added resistance in series and parallel, keeping impedance a constant 8 ohm load. This stereo L-pad is rated at 100 watts RMS, is designed to be used with two 8 ohm loads, features a 1" shaft length, and comes with mounting hardware.
  • Easy level adjustment of two 8 ohm loads without changing impedance
  • Maintains constant 8 ohm impedance
  • Great for speaker design tweaking
  • Mounting hardware included
Your Price: $54.98
Save $17.01 (24%)
We'll send you an email when Parts Express Speaker L-Pad Attenuator 100W Stereo 1" Shaft 8 Ohm is back in stock or available for preorder.
Estimated back in stock 10/15/2026
L-pads adjust the relative volume of drivers connected to them by placing added resistance in series. At the same time, a counter-resistance is placed in parallel with the driver to maintain a constant impedance which allows the original crossover design to be used. L-pads are to be placed in between the amplifier and speaker, or in between the crossover and driver. This stereo L-pad is rated at 100 watts RMS, is designed to be used with two 8 ohm loads, features a 1" shaft length, and comes with mounting hardware, faceplate, and volume control knob.
Dimensions: 2-1/2" diameter, 2" depth.
L-Pad Instruction Diagram
Part Number260-264
UPC844632017759
Weight0.7194
