  • Denovo Audio Knock-Down MDF 3.0 cu. ft. Cubic Foot Subwoofer Cabinet
CLEARANCE Denovo Audio Knock-Down MDF 3.0 cu. ft. Cubic Foot Subwoofer Cabinet
Denovo Audio Inc
Part #300-7087
Denovo Audio Inc
Part #300-7087
Build the ultimate subwoofer using this extremely rigid, knock-down, three cubic foot subwoofer cabinet. Extremely well thought out, this cabinet includes precision-machined panels that include dadoes, a double-thick front baffle, and a unique two-piece brace system.
  • CNC-machined dadoes and a unique bracing system that increases cabinet rigidity
  • Double-thick 1-1/2" front baffle
  • 3 cubic foot cabinet made of 3/4" MDF panels
  • Carb 2 compliant material
Even the easiest do-it-yourself subwoofer can turn into an arduous project; from uneven cuts, to measuring mistakes. CNC knock-down cabinets make it easy for the beginner to end up with amazing finished results without all of the time and effort necessary to perfect your woodworking skills. This cabinet is designed for speaker builders and designers who don't have access to expensive tools or a woodshop.
During the CNC manufacturing process, rabbets dadoes are cut into the back panel for precise panel alignment. A unique two-piece brace adds superior rigidity without affecting the subwoofer's performance. Both side panels feature 3/4" rabbeted extensions with recesses to perfectly install the first piece of the two-part, double thick baffle. Plate amplifier installation is made easy by following the scribed interior guide with a jig saw and by modifying one of the braces.
Specifications: • Panel thickness: 3/4", front baffle is 1-1/2" • Panel material: Medium Density Fiberboard (MDF) • Finished net cabinet volume (subtracting the double thick baffle, bracing, and estimated woofer volume): 3.0 cubic feet • External dimensions: 19.25" H x 19.25" W x 20" D • Weight: 52 lbs. • Made in the U.S.A.
BrandDenovo Audio Inc
Part Number300-7087
UPC848864018362
Weight58.8
