  • Klipsch PIC-800-T BW 8" Professional In-Ceiling Speaker 8 Ohm / 70V
KlipschPart # 247-2070
Model: PIC-800-T BW
The Klipsch PIC-800‑T is a rugged, high-performance 8″ in‑ceiling speaker designed for demanding indoor and outdoor environments. It delivers enhanced bass output, effortless clarity, and versatile installation in professional and residential systems alike.
  • Patented Tractrix® Hyperfold Port provides “more bass, less space” for a compact but powerful performance
  • Exclusive patented Sky Hook® Pro system for quick, tool-free installation
  • 1" titanium compression driver provides clear, wide dispersion of high frequencies
  • IPX5 rating offers weather resistance for patio and porch usage
  • Multi-tap transformer allows for 70/100 V distributed systems with an 8Ω bypass for flexibility
  • Phoenix connector simplifies wire connections for installer convenience
  • Paintable, black and white grilles included to blend seamlessly into any décor
Dayton Audio CC80TPW 8" 2-Way 70V In-Ceiling Speaker Pair
Price: $144.98Part # 300-427
See all items in In-ceiling Speakers
Your Price: $449.99
We'll send you an email when Klipsch PIC-800-T BW 8" Professional In-Ceiling Speaker 8 Ohm / 70V is back in stock or available for preorder.
Klipsch PIC Professional In-Ceiling Speakers
More Bass, Less Space with the All-New Tractrix® Hyperfold Port™
Klipsch focuses on high efficiency and low distortion. Continuing that legacy, the all-new patented Tractrix® Hyperfold Port™ is engineered with a proprietary five-step folded design to extend port length for maximum bass power. Increased airflow eliminates chuffing and port noise while delivering a wider dispersion pattern for larger coverage areas.
Exclusive Patented Sky Hook® Pro System for Faster, Tool-Free Installation
The Klipsch PIC Series is designed for quick and simple installation once the hole is cut. Featuring the exclusive patented Sky Hook® Pro, the tool-free system allows you to install without worrying about torque settings or even needing a screw gun. With a simple click of four buttons, the PIC Series is securely in place.
IPX5 Rated for Challenging Commercial Environments
Built for demanding commercial use worldwide, this product in the Klipsch PIC Series is IPX5 Rated. This rating provides maximum weather resistance, giving clients peace of mind in even the toughest conditions.
1" Titanium Compression Driver for Effortless, High-Clarity Detail
Outperforming the competition, the all-new 1” Titanium-loaded floating driver bridge includes a wide dispersion phase plug. Combined with Klipsch’s patented Mumps technology, the PIC Series delivers extra-wide coverage with consistent, even energy across any space.
Black and White Paintable Grille Options Included
Designed to blend into any environment, the Klipsch PIC Series comes packaged with both black and white grilles.
Phoenix Connectors for Simplified Installation
For quick and intuitive setup, the PIC Series uses a phoenix connector that simplifies the installation process.
Use as a Pendant Speaker
With the addition of the Klipsch KPH-800 housing, turn this ceiling speaker into a pendant speaker. This provides the same efficiency and clarity of the PIC and IC series in a suspended design ideal for distributed sound in high-ceiling installations. Available in black and white.
PIC-450-TPIC-525-TPIC-525-T-SCPIC-650-TPIC-800-TPIC-800-SW
Frequency Response
64Hz-20kHz +/- 4dB, 54Hz -10dB
62Hz-20kHz +/- 4dB, 52Hz -10dB
95Hz-20kHz +/- 4dB, 60Hz -10dB
60Hz-20kHz +/- 4dB, 50Hz -10dB
56Hz-20kHz +/- 4dB, 46Hz -10dB
40Hz-200Hz +/- 4dB, 32Hz -10dB
Power Handling50 watts (14.6V) 58Hz-10kHz (200 watts peak)
65 watts (16.7V) 55Hz-10kHz (260 watts peak)
80 watts (19V) 53Hz-10kHz (320 watts peak)
100 watts (21V) 50Hz-10kHz (400 watts peak)
150 watts (25.4V) 40Hz-200Hz (600 watts peak)
Calc. Max. Cont. Output102dB104dB104dB106dB109dB108dB
Sensitivity88dB89dB89dB90dB92dB89dB
Coverage90° +/- 40° 1kHz-20kHz
100° +/- 20° 1kHz-20kHz
100° +/- 20° 900Hz-20kHz
Directivity Index7dB +/- 3dB 800Hz-20kHz
7dB +/- 1.5dB 1kHz-20kHz
7dB +/- 1.5dB 800Hz-20kHz
Nominal Impedance8 ohms, 4.3 ohms at 185Hz minimum
8 ohms, 4.3 ohms at 175Hz minimum
8 ohms, 4.5 ohms at 160Hz minimum
8 ohms, 4.2 ohms at 150Hz minimum
8 ohms, 4.2 ohms at 40Hz minimum
Acoustic Crossover2kHz2kHz
2kHz
2kHz
2kHz
Transducers4.5” woofer
1” titanium compression driver, on a K-1500 TRACTRIX horn/tweeter bridge
5.25” woofer
1” titanium compression driver, on a K-1200M Tractrix horn/tweeter bridge
5.25” woofer
6.5” woofer
8” woofer
8" Woofer
Enclosure MaterialAll Weather Abs Plastic, Paintable; Metal Can
IP RatingIPX6IPX5IPX5
IPX5
IPX5
IPX6
Enclosure TuningVented via 3 folded Tractrix ports
Input Connectors4 pin euro block
4 pin euro block
4 pin euro block
4 pin euro block
4 pin euro block
4 pin euro block
Transformers Taps70V: 15W, 7.5W, 3.8W, 1.9W
100V: 15W, 7.5W, 3.8W
Bypass position: 8 ohms nominal
70V: 30W, 15W, 7.5W, 3.8W
100V: 30W, 7.5W, 3.8W
Bypass position: 8ohms nominal
70V: 60W, 30W, 15W, 7.5W
100V: 60W, 30W, 7.5W
70V: 100W, 50W, 25W,12.5W
100V: 100W, 50W, 25W
70V: 70W, 35W
100V: 70W, 35W
Cutout Dimension9.125"9.125"10.125"
10.125"12.5"12.5"
Mounting Depth7.313"7.313"3.875"9.438"10.313"10.313"
Overall Depth7.438"7.438"4.438"9.563"10.375"10.375"
Overall Width10.625"10.625"11.25"11.25"13.625"13.625"
Thru Hole Width8.875"8.875"10"10"12.313"12.313"
Weight8 lbs.9 lbs.8 lbs.11 lbs.17 lbs.27 lbs.
BrandKlipsch
ModelPIC-800-T BW
Part Number247-2070
UPC743878057676
Weight28
Input Rating8 ohm|70V|100V
Mounting StyleIn-ceiling
Woofer Diameter8"
Special FeaturesEnclosed Back
