  • Klipsch Flexus Surr 100 Wireless Surround Sound Speaker Pair
NEW Klipsch Flexus Surr 100 Wireless Surround Sound Speaker Pair
KlipschPart # 247-2057
Model: Flexus Surr 100
The Klipsch Flexus SURR 100 speakers are compact wireless rear surrounds designed to bring immersive Dolby Atmos surround sound to your home theater setup. Individually powered and elegantly styled, they provide clean integration with Klipsch Flexus Core soundbars and offer a seamless expansion path.
  • Authentic Dolby Atmos surround sound for immersive, theater-like experiences
  • 3" paper cone driver with 50 W RMS amp delivers clear and dynamic performance
  • Up to 103.5 dB output brings powerful sound effects into your room
  • Compact sealed cabinet with ebony vinyl finish blends seamlessly into your space
  • Wall-mount option with 1/4-20 threaded insert makes placement flexible and simple
  • Klipsch Transport wireless technology allows fast pairing without messy cabling
  • Hidden controls and eco-friendly packaging combine clean looks with sustainability
NEW $249.99
We'll send you an email when Klipsch Flexus Surr 100 Wireless Surround Sound Speaker Pair is back in stock or available for preorder.
Surrounded with Awesomeness
Adding Klipsch Flexus Surround Speakers transforms your system into a true multichannel experience, expanding sound beyond the front stage. With Dolby Atmos technology, these speakers project audio not only around the room but also overhead, creating an immersive 3D sound field. Whether you’re listening to music, watching movies, or gaming, you’ll enjoy realistic sound placement that enhances depth, detail, and overall impact for a theater-like performance at home.
Powered by Onkyo
Klipsch has teamed up with Onkyo, combining their decades of proven manufacturing and tech prowess with Klipsch's classic acoustics, to ensure your home entertainment system is as epic in audio quality as it is in reliability.
Simple Setup, Sleek Style
The Flexus Surround Speakers keep things simple and elegant by being individually powered, so there are no bulky junction boxes or adapters to hide. All of the controls, power connections, and LED indicators are tucked neatly below the surface, giving you a distraction-free listening environment even in total darkness. The result is a streamlined solution for multichannel home theaters that looks as clean as it sounds, letting the immersive audio take center stage.
You're In Control
With the Klipsch Connect Plus app, you can access EQ presets or create your own custom EQ mix, activate Night Mode, boost dialogue for clearer speech, adjust the volume, and enjoy additional features as they become available.
Download for iOS
Download for Android
Flexible Placement
The Flexus Surround Speakers are designed for flexible placement and clean integration into your home theater. A 1/4-20 threaded insert on the back makes wall mounting easy, helping you position them for maximum immersion. Power is located on the bottom of the speaker, easy to reach when wall mounted but not an obstruction either for placing on a flat surface.
Independently Powered
The Flexus Surround Speakers make setup completely hassle-free. There are no adapters, dongles, or long speaker wires to manage, which means you won’t be running cables across the floor or hiding bulky connectors. Each speaker simply plugs into a wall outlet with its own discrete power cable, so they remain streamlined, uncluttered, and easy to place anywhere in your home theater.
  • Speaker System: 2.0 Wireless Surround (Pair)
  • Max Acoustic Output: 103.5dB @ 1M Anechoic pair
  • Full Range Driver: 3” Paper Cone
  • Enclosure Type: Sealed - Plastic, Metal
  • System Power: 50W RMS
  • Frequency Response: 235Hz - 20kHz
  • Height: 6.75” (171mm)
  • Width: 4.13” (105mm)
  • Depth: 4.31” (109.5mm)
  • Weight: 2.5lbs (1.13kg) each
  • Finish: Ebony Vinyl
  • Voltage: 100-240V 50/60Hz Internal Power Supply
  • USB Port:
    (1) USB Type-C Connection
    For System Updates and playback of MP3 files for test and debug purposes.
  • Included Accessories:
    (2) 2.0m Right-Angle IEC Power Cord (Region Specific)
    (1) Flexus Transport Wireless dongle
    (1) User Manual
  • Mounting: 1/4” x 20 Threaded Insert
  • USB Input:
    (1) USB Type-A Connection
BrandKlipsch
ModelFlexus Surr 100
Part Number247-2057
UPC743878066487
Unit of MeasurePairs
Weight8.65
ColorBlack
ConfigurationFull-range
Mounting StyleSet-Top
Woofer Diameter3"
Special FeaturesWireless
