  • KAS2230DLC Splash Waterproof Bi-Directional Sound Projector Speaker 70V
BUYOUT KAS2230DLC Splash Waterproof Bi-Directional Sound Projector Speaker 70V
Factory BuyoutsPart # 299-4288
Model: KAS2230DLC
The KAS2230DLC Splash Waterproof Bi-Directional Sound Projector Speaker is an outdoor surface mount speaker designed to take a beating by the elements.
  • IEC529, IPX6 rated for outdoor longevity
  • 2.5W, 5W, 10W, 15W, 20W and 8 ohm tap settings for installation versatility
  • High SPL for covering large areas
  • Bi-directional makes it great for hallways or corridors
BUYOUT $29.88
MSRP: $79.99
Save $50.11 (63%)
1 In Stock
We'll send you an email when KAS2230DLC Splash Waterproof Bi-Directional Sound Projector Speaker 70V is back in stock or available for preorder.
Order in the next 10 hr 11 min to ship today. Details
The KAS2230DLC Splash Waterproof Bi-Directional Sound Projector Speaker is an outdoor surface mount speaker designed to take a beating by the elements. It features an all ABS plastic housing that is UV protected, a powder-coated metal mounting bracket and stainless hardware.
It's dual 6" full-range speakers fire bi-directionally, making this a great choice for hallways, corridors or filling large areas with sound coverage. A built-in 70-volt transformer provides five different tap settings, as well as an 8 ohm bypass. The design helps direct the sound where you want it to go and boosts overall efficiency, allowing you do aim the sound to whichever area you need.
  • 7.25"W x 12.25"D (including mounting bracket)
  • 70.7V tap settings: 5W, 10W, 15W, 20W, 8 ohm
  • Frequency response: 80 to 20,000 Hz
  • SPL: 92dB, 107dB Max
  • IEC529, IPX5 rated
BrandFactory Buyouts
ModelKAS2230DLC
Part Number299-4288
UPC848864073897
Weight7.85
