  • Jensen JT-MB-C 1:1 Premium Microphone Bridging Transformer
1 Question, 5 Answers or
Jensen Transformers
Part #246-0112
Jensen Transformers
Part #246-0112
Model: JT-MB-C
The JT-MB-C microphone bridging transformer from Jensen is typically used to split one mic signal to two destinations, isolated, noise-free and with minimal loss of signal. You'll find this and other Jensen transformers in many top-of-the-line "boutique" brands for one simple reason: they're the best.
Your Price: $99.99
If you're building your own or upgrading an existing mic splitter, the JT-MB-C from Jensen is the best transformer for the job. Full-range frequency response is delivered with surgical precision, with multiple layers of protection from distortion, hum, buzz, and RF interference.
Jensen's MuMETAL® shielding is known the world over for its protection against the intrusion of magnetic field or RF interference. Jensen has also designed and implemented multiple Faraday shields to further safeguard your signal from unwanted noise that can ruin your live performance or studio recording. Without getting deep into a bunch of scientific mumbo-jumbo, let's just say Jensen is the best you can get, and that's why the top names in music, recording, and broadcasting won't use anything else. Go with what the pros know. Jensen. The world's finest transformers.
See the Project Design Schematics under Manuals/Resources for application schematics.
Specifications: Impedance ratio: 150:150 • Turns ratio: 1:1 • Max input (@ 20 Hz): +2 dBu • THD (@ 20 Hz): 0.050% • Dimensions: 1.13” diameter x 1.03” • Wire leads: 30 AWG UL style color coded, 8” minimum length.
BrandJensen Transformers
ModelJT-MB-C
Part Number246-0112
UPC848864028606
Weight0.18
