  • Jensen Iso-Max PI-2XX Dual Channel XLR Line Input Isolator
Jensen TransformersPart # 246-0124
Model: PI-2XX
Jensen's Iso-Max isolators use the world's best transformers to solve a problem common to pro audio, home theater, car audio, and audiophiles alike: the dreaded HUM. The PI-2XX is a two channel isolator for line level XLR signals. Connect it between your source and destination to eliminate hum without adding noise or killing quality.
  • Hum / ground loop eliminator for line level XLR
  • Built using the finest transformers money can buy: Jensen
  • Passive design means no power or batteries needed
  • Rugged construction for long service life
Your Price: $399.99
MSRP: $439.99
Save $40.00 (9%)
We'll send you an email when Jensen Iso-Max PI-2XX Dual Channel XLR Line Input Isolator is back in stock or available for preorder.
Estimated back in stock 2/20/2026
The PI-2XX is used to remove ground-loop hum from signals in virtually any sound application where line level signal is carried via XLR connections. With high quality XLR cables, connect the PI-2XX between your source device and your destination input. Jensen recommends having the PI-2XX near your destination device (3 ft. or less cable is best).
We've all been there before. You spend hard-earned money and hours of your time selecting just the right components and putting together a great sound system. You get everything hooked up, plug it in and fire it up and BAM! That dastardly hum rears its ugly head. It's not just an audiophile issue. It happens anywhere you might want to install high quality sound. Home theater, mobile audio, pro audio and commercial sound systems can all be plagued by this most vile and wretched affliction.
Lucky for you, Jensen has introduced solutions for virtually any type of setup in which you might encounter this pernicious foe. Using world-renowned Jensen transformers, the Iso-Max line of products kills the hum without killing your sound quality. Simply insert the Iso-Max unit into your signal path, and voilà! Hum is out, and clean luscious sound is all that's left. Enjoy!
Specifications: Frequency response: < 5 - 40,000 Hz • Connectors: XLR and removable barrier strip • Max input (@ 20 Hz): +19 dBu • CMRR noise rejection: 95 dB @ 60 Hz • Dimensions: 6.94" x 3.5" x 1.71".
BrandJensen Transformers
ModelPI-2XX
Part Number246-0124
UPC676101041602
Weight1.86
