  • Jantzen Audio 0.40mH 15 AWG Litz Wire Wax Inductor
Jantzen AudioPart # 255-912
Model: 000-L-0040
The Jantzen Audio Litz Wire Wax Coil is a wax-impregnated litz wire inductor designed for loudspeaker crossover applications where reduced distortion and compact size are priorities. Co-engineered with Audiothlon in Poland, it targets a balance between performance and cost, positioned between traditional wire-based and foil-based inductors.
  • Co-engineered with Audiothlon in Poland
  • Wax impregnation reduces unwanted distortion and microphonic effect
  • Designed as a performance and price balanced alternative to foil inductors
  • Reduced skin effect and lowered resistance compared to single wire inductors
  • Inductance tolerance of ±3%
  • DCR (coil resistance) tolerance of ±5%
Your Price: $22.68
MSRP: $34.99
Save $12.31 (35%)
Quantity:Qty: 1-9 $22.68/ea
Quantity:Qty: 10+ $20.41/ea
Out of Stock
We'll send you an email when Jantzen Audio 0.40mH 15 AWG Litz Wire Wax Inductor is back in stock or available for preorder.
Jantzen Audio Litz Wire Wax Inductors
Product Features
The Litz Wire Wax Coil is the only wax impregnated litz wire coil on the market.
The Litz Wire Wax Coil was co-engineered with Audiothlon in Poland.
Audiothlon was looking for an inductor with a price-point and performance level placed somewhere in the middle between wire-based and foil-based inductors.
The advantage of Litz Wire Coils is that they have many of the advantageous properties of foil-based inductors but are smaller in size and lower in cost.
Depending on the specific crossover design, the litz wire coils can be a good substitute for foil-based inductors.
Litz wire enables inductors to have reduced skin effect and lowered resistance, which in turn offers more dynamic headroom, compared to single wire-based inductors.
The wax impregnation secures the integrity of the windings and greatly reduces unwanted distortion and microphonic effect
Technical Data
  • Made from ETP (Electrolytic-Tough-Pitch) C11000 / IACS certified copper wire
  • Available in 14 AWG (7 x 0,63 mm stranded wires) and 15 AWG (7 x 0.5 mm stranded wires)
  • Wax impregnated to greatly reduce unwanted distortion and microphonic effect
  • The wire is designed to reduce skin and proximity effect losses in conductors up to frequencies of approx. 1 MHz
  • Inductance tolerance: ±3%
  • DCR (coil resistance) tolerance: ±5%
Electrical Properties
  • Inductance: 0.4000 mH
  • DCR: 0.2100 Ω
  • Wind. Wire: 1.40 mm
  • AWG: 15
Dimensions
  • Inner ø: 25 mm
  • Outer ø: 49 mm
  • Height: 30 mm
BrandJantzen Audio
Model000-L-0040
Part Number255-912
UPC848864055824
Weight0.45
DCR0.22Ω
Inductance0.4mH
Inductor TypeAir Core
Wire Gauge15
