  • JBL Selenium D405-X 2" 110 Watt Bolt-On Compression Driver 8 Ohm
CLEARANCE JBL Selenium D405-X 2" 110 Watt Bolt-On Compression Driver 8 Ohm
SeleniumPart # 264-486
Model: D405-X
The JBL Selenium D405-X is a top-tier 2" bolt-on compression driver designed to deliver outstanding audio performance. This driver is ideal for professional sound systems and demanding audio applications. Its robust design and JBL Selenium engineering ensure consistent, long-lasting performance.
  • Dome-type phenolic diaphragm for efficiency and durability
  • Easily replaceable in an emergency
  • Great for multi-way PA systems
  • Exceptional sound clarity and detail
B&C DCX462-8 2" Neodymium Coaxial Compression Driver 8 Ohm 4-Bolt
Price: $791.10Part # 294-6082
See all items in Horn Drivers
We'll send you an email when JBL Selenium D405-X 2" 110 Watt Bolt-On Compression Driver 8 Ohm is back in stock or available for preorder.
The JBL Selenium D405-X is a 2" compression driver that delivers exceptional audio performance. With an impressive 110-watt continuous power rating, this driver handles demanding audio applications with ease while maintaining clear and powerful sound. Its bolt-on means a secure, stable driver in your cabinet. Advanced engineering offers crisp and articulate audio across a wide frequency range, making it ideal for vocals, instruments, and other mid-range sounds.
Constructed with high-quality materials, the D405-X is built to withstand the rigors of frequent use, ensuring long-lasting performance. This durability guarantees peak performance over time, providing reliable sound reproduction for years to come. The D405-X's versatility allows for flexible integration into various audio setups, making it a reliable choice for both professional and amateur audio engineers.
Specifications: • Power handling: 110 watts RMS/220 watts program (w/ xover 1,000 Hz 12dB/oct) • Voice Coil Diameter: 4" • Throat diameter: 2" • Impedance: 8 ohms • Frequency response: 500-6,500Hz • SPL: 110 dB 2.83V/1m • Magnet weight: 76 oz.
BrandSelenium
ModelD405-X
Part Number264-486
Weight14.55
Diaphragm MaterialPhenolic
Exit Diameter2"
Mounting Type4-Bolt
Power Handling (RMS)110 Watts
