  • JBL Control 28-1 8" 2-Way Indoor/Outdoor Speaker Pair 70V / 100V / 8 Ohm - Black
CLEARANCE JBL Control 28-1 8" 2-Way Indoor/Outdoor Speaker Pair 70V / 100V / 8 Ohm - Black
JBL ProfessionalPart # 246-8548
Model: Control 28-1
The Control 28-1 from JBL is a two-way 8" speaker with rich sonic character, wide coverage, consistent dispersion, versatile mounting, and an updated sleek, contemporary look that fits into a wide range of decors. Control 28-1 speakers now include a 70V / 100V transformer with 8 ohm bypass, further increasing their value and versatility.
  • 5" 2-way installation speakers
  • Durable, weather-resistant construction
  • Stylish contemporary design
  • Sold in pairs only
CLEARANCE $762.00
3 In Stock
We'll send you an email when JBL Control 28-1 8" 2-Way Indoor/Outdoor Speaker Pair 70V / 100V / 8 Ohm - Black is back in stock or available for preorder.
The Control 28-1 by JBL is an excellent choice for a wide variety of applications, including retail stores, restaurants, health clubs, theme parks, educational facilities, hospitality, music cafes, leisure venues, and anywhere where a top quality compact indoor/outdoor foreground/background music (and/or paging) speaker is required.
JBL's Contractor Series surface-mount speakers are loaded with complication-reducing innovations. Rugged molded high-impact polystyrene (HIPS) enclosures balance mass, strength, and resonance, perfectly complementing their respective transducers. The symmetrical 100° x 100° dispersion geometry delivers precise directability and control. Compact design dimensions and textured, ready-to-paint exterior surfaces make the Control Contractor Series unobtrusive in any decor. JBL's Invisiball™ mounting system (patent pending), innovative bracketing solutions, and factory-installed autoformers take the headaches out of installation.
Extensive use of high-tech materials adds years to speaker life expectancy while increasing weather resistance. The Control 28-1 exceeds MilSpec 810 for humidity, salt-spray, temperature & UV, and passes MilStd-202F for salt spray and ASTM G85 for acid-air plus salt spray. For extreme environments, MTC-23WMG-1 WeatherMax™ grilles and MTC-PC2 protective panel covers (both sold separately) may be added to increase the IEC rating from IP-44 to IP-55.
Specifications: • Frequency range(-10 dB): 45 - 20,000 Hz • Frequency response (±3 dB): 62 - 16,000 Hz • Power rating (8 ohm setting): 240W continuous program • Maximum input voltage: 27.5 Vrms; 55 peak • Maximum SPL: 112 dB avg; 118 dB peak • Sensitivity: 91 dB 1W/1m (avg., 100 - 10kHz) • Coverage angle: 100° x 100° • Directivity factor (Q): 7.3 (avg. 1kHz - 16kHz) • Directivity index (DI): 8.3 dB (avg. 1kHz - 16kHz) • Tap settings: (70V) 60W, 30W, 15W, 7.5W; (100V) 3 60W, 30W, 15W • THRU setting: 8 ohms nominal • Recommended high-pass protection: 45 Hz, 24 dB/oct • Termination: screw-down terminal strip • Dimensions: 15.2" x 11.1" x 8.6" (277 x 282 x 219 mm) • Weight (per speaker): 6.8 lbs. (15.0 kg) • Sold in pairs.
BrandJBL Professional
ModelControl 28-1
Part Number246-8548
UPC691991002052
Unit of MeasurePairs
Weight33.15
ColorWhite
Configuration2-way
Input Rating8 ohm
Mounting StyleWall Mount
Woofer Diameter8"
Special FeaturesIndoor/Outdoor
