  • JBL Control 1 Pro 5-1/4" 2-Way Shielded Speaker Pair Black
JBL ProfessionalPart # 246-8500
Model: C1PROAM
Legendary JBL Professional performance housed in a compact form-factor; the Control® 1 Pro features a professional crossover network coupled with professional drivers making it ideal for even the most demanding near-field audio applications.
  • Transparent and faithful sonic performance
  • Magnetically shielded transducers
  • SonicGuard&#153 overload protection
  • Mounting bracket included
  • Spring loaded input terminals
Your Price: $240.00
MSRP: $284.00
Save $44.00 (15%)
We'll send you an email when JBL Control 1 Pro 5-1/4" 2-Way Shielded Speaker Pair Black is back in stock or available for preorder.
Legendary JBL Professional performance housed in a compact form-factor; the Control® 1 Pro features a professional crossover network coupled with professional drivers making it ideal for even the most demanding near-field audio applications. The Control 1 Pro's updated crossover network design provides steeper crossover slopes for exceptional sonic performance and improved consistency throughout the listening area. Full-range SonicGuard™ power limiting protects the network and transducers An included wall-mount bracket enables the unit to be secured against a wall or other flat surface. The rugged molded enclosure houses magnetically shielded transducers, making the Control 1 Pro well suited for use with video and computer monitors, or other magnetically sensitive equipment. Components: 5-1/4" woofer, 3/4" polycarbonate dome tweeter.
Specifications: • Power handling: 150 watts continuous program • Frequency response (-10 dB): 100 Hz to 18 kHz • Frequency response (± 3 dB): 100 Hz to 18 kHz • Nominal impedance: 4 ohms • Sensitivity: 87 dB 1W/1m • Crossover frequency: 4.2 kHz • Weight: 4 lbs • Dimensions: 9.3" x 6.3" x 5.6".
The Control Series is pure JBL, combining high performance, compact design, and rugged construction into a line of loudspeaker systems with unprecedented versatility. The Control Series is also one of the most easily installed systems available anywhere. Perfect for applications where tight corners and tough angles are all too common, the Control Series features a wide variety of available mounting systems allowing enclosures to be easily positioned for optimum performance.
BrandJBL Professional
ModelC1PROAM
Part Number246-8500
UPC050036903455
Unit of MeasurePairs
Weight11.65
ColorBlack
Configuration2-way
Input Rating4 ohm
Woofer Diameter5.25"
