  • Home Theater Speaker Wiring Kit with 10 ft. HDMI 2.0 Cable
Parts ExpressPart # 180-1201
Setting up your new 5.1 home theater system can be an exhilarating experience, and with the right cables in hand, you can effortlessly transform your living space into a cinematic paradise. Embrace the joy of high-quality sound and stunning visuals with our specially curated A/V wiring kit, designed to save you both time and money.
  • 100 ft. of 16 gauge CCA stranded speaker wire for superior flexibility
  • 12 ft. 24 AWG stranded OFC center conductor, 100% shielded, gold-plated connector subwoofer cable for interference free signal transfer
  • HDMI cable supports High Dynamic Range (HDR) and 4K@60 Hz at 16-bit color depth (4:4:4) compatibility for striking video imagery
Your Price: $12.94
Save $17.06 (57%)
84 In Stock
Replacing Included Cables
Many home theater systems come with the hook cables, but they're either too short, missing or poor quality. This home theater wiring kit's design works for almost any standard room and hookup requirements.
100 ft. CCA 16 Gauge Speaker Wire
This 100 ft. of 16 gauge CCA speaker is flexible enough to bend around corners and long enough to reach those rear surround sound speakers. Most prepackaged home theater systems give you 22 gauge speaker wire, which is okay for very short runs, but reduces low frequency response when using more than 6 ft. for each speaker.
12 ft. 100% Dual Shielded OFC Core Subwoofer Cable
Subwoofers deliver the most bass when installed in the corner of your home theater room. This 12 ft. cable not only reaches to most corners, but is double shielded to make sure no interference interrupts your sound. Oxygen free copper stranded core for maximum signal transfer and flexibility.
12 ft. Prograde Ultra HD HDMI 2.0 Cable
Using this Audtek Prograde 4K HDMI 2.0 cable will ensure that you get the full potential of 4K UHD content when available. Trust this HDMI cable to transfer 18 Gbps transmission bandwidth from your source without downgrading your video signal. This cable supports 4K@60 Hz at 16-bit color depth (4:4:4) so no matter what 4K TV you have, you will realize its full potential with this HDMI cable. Other features included with this high speed is Ethernet compatibility, an audio return channel, gold plated contacts, 30 AWG wires, and improved 3D support.
Part Number180-1201
UPC848864068657
Weight1.75
