  • HiVi CF240 4" 2-Way Coaxial Car Speaker Pair
CLEARANCE HiVi CF240 4" 2-Way Coaxial Car Speaker Pair
HiViPart # 267-8100
Model: CF240
The HI-Vi CF240 4" coaxial is an excellent upgrade over the low quality speakers used in most stock car stereo systems. The damped polypropylene cone, high loss rubber surround, and 3/4" soft dome tweeter combine to provide smooth response and natural sound.
  • 3/4" soft dome tweeter with neodymium motor for detail without harshness
  • Polypropylene cone with rubber surround for natural response and long life
  • Installs easily into common 4" dash and door openings
  • Includes grilles, mounting rings, gaskets, wire, and hardware for easy installation
CLEARANCE $56.24
MSRP: $101.99
Save $45.75 (45%)
1 In Stock
We'll send you an email when HiVi CF240 4" 2-Way Coaxial Car Speaker Pair is back in stock or available for preorder.
As drop-in OEM replacement upgrades, Hi-Vi's CF series coaxial speakers will provide outstanding performance for an incredible value. The common size and shallow mounting depth ensure that the CF240 will fit right into most factory 4" driver openings without issues. A polypropylene cone, and rubber surround has been used to withstand the harsh automotive environment while providing smooth response. The high power motor combined with a 1" voice coil make the CF240 efficient for its size while handling enough power for continuous high output use. The coaxially mounted, neodymium 3/4" soft dome tweeter is designed to provide exceptional off axis response and non-fatiguing sound with low distortion.
Specifications:• Power handling: 30 watts RMS/90 watts max • Impedance: 4 ohms • Frequency response: 85-23,000 Hz • SPL: 87dB • Overall diameter: 4" • Mounting depth: 2-1/4"
BrandHiVi
ModelCF240
Part Number267-8100
UPC848864059754
Unit of MeasurePairs
Weight5.2
Speaker Size4"
Speaker Type2-Way
Power Handling (RMS)30 Watts
