  • Gemini XGA-4000 Professional Power Amplifier
GeminiPart # 235-190
Model: XGA-4000
Experience the ultimate in live sound reinforcement with the Gemini WPX-4000 Modular Line Array Speaker System. Designed for versatility and performance, the WPX-4000 brings crystal-clear audio and powerful output to any event.
  • High Power Output: Delivers a solid 4000 watts of peak power, providing ample volume for a wide range of venues and applications.
  • Exceptional Sound Quality: Ensures clean, clear audio reproduction with minimal distortion, even at high output levels.
  • Versatile Connectivity: Equipped with balanced XLR and 1/4" TRS inputs, plus Speakon and binding post outputs, for flexible hook-ups.
  • Rugged Construction: Built with a durable chassis and components designed to withstand the rigors of road use and demanding environments.
  • Efficient Thermal Management: Features a continuous variable-speed fan and extensive heat dissipation mechanisms for reliable performance under continuous use.
Your Price: $219.95
Save $140.00 (39%)
We'll send you an email when Gemini XGA-4000 Professional Power Amplifier is back in stock or available for preorder.
The Gemini XGA-4000 Professional Power Amplifier is at the forefront of audio amplification, delivering the power and reliability required by professional sound engineers and performers. With its high output capacity and crystal-clear sound reproduction, the XGA-4000 stands out as a top choice for those who refuse to compromise on audio quality.
The XGA-4000 is engineered to pump out 4000 watts of peak power, ensuring your sound is heard loud and clear in any setting. From outdoor festivals to intimate indoor gatherings, this amplifier provides the volume you need without sacrificing sound quality.
Clarity is king with the XGA-4000. It's designed to minimize distortion and maintain audio integrity across all volume levels, delivering sound that’s true to the original recording. Whether you’re amplifying live vocals, instruments, or playback, expect nothing less than exceptional sound.
Adaptability is essential in professional audio setups. The XGA-4000 meets this need with a range of input and output options, including balanced XLR and 1/4" TRS inputs, along with Speakon and binding post outputs. This versatility ensures seamless integration into any existing sound system.
Designed with the touring artist and busy venue in mind, the XGA-4000 boasts a rugged construction that can take a beating. Its solid build protects it from the bumps and bruises of the road, ensuring longevity and reliable performance night after night.
When the heat is on, the XGA-4000 stays cool, thanks to its efficient thermal management system. A continuous variable-speed fan and superior heat dissipation design keep the amplifier running smoothly, preventing overheating and ensuring uninterrupted performance during prolonged use.
  • Power Output: 2x 350W RMS at 4 Ohms Stereo 2x 250W RMS at 8 Ohms Stereo 700W RMS at 8 Ohms Bridged
  • Frequency Response: 10 Hz to 50 kHz
  • Signal to Noise: >90 dB
  • Total Harmonic Distortion: Less than 0.1%
  • Inputs: XLR and ¼” balanced and RCA unbalanced
  • Outputs: 3 Speakon outputs for Channels A/B/Bridge 5-way binding banana plug channel outputs
  • Modes: Stereo & Mono Bridge
  • Rack Size: 2U
  • Voltage 100V/250V / 50/60hz
BrandGemini
ModelXGA-4000
Part Number235-190
UPC747705204417
Weight23.65
