  • Gemini ES-210MXBLU 10" Portable PA System Pair
CLEARANCE Gemini ES-210MXBLU 10" Portable PA System Pair
GeminiPart # 235-141
Model: ES-210MXBLU
The Gemini ES-210MXBLU is a 600-watt portable PA system designed for DJs, event hosts, fitness instructors, and worship leaders seeking a compact, all-in-one audio solution. Featuring dual 10-inch passive speakers powered by a 6-channel mixer with Bluetooth connectivity, this system offers versatile input options and robust sound projection for various live sound applications.
  • 600W peak power delivers clear, dynamic audio for medium-sized venues
  • Bluetooth streaming enables wireless playback from smartphones and tablets
  • 6-channel mixer with EQ and effects provides versatile sound control
  • Includes dual 10" speakers, microphone, and speaker cables for a complete setup
  • Compact, portable design with integrated handles for easy transport​
  • One active and one passive speaker makes setup easy
  • Four MIC/LINE input channels and EQ/FX allow you to tailor the mix to your needs
Gemini AS-2115BT-PK 15" Bluetooth Active Loudspeaker Pack
Price: $269.95Part # 235-148
See all items in PA Speaker Systems
CLEARANCE $329.95
1 In Stock
We'll send you an email when Gemini ES-210MXBLU 10" Portable PA System Pair is back in stock or available for preorder.
Bluetooth Connectivity
Stream music wirelessly from any Bluetooth device with up to 30 feet of range.
Built-in Media Player
Play MP3, WAV, and FLAC audio files directly from a USB drive or SD card.
6-Channel Mixer
Includes four MIC/LINE input channels with adjustable EQ, built-in FX, and clip meter LEDs.
600-Watts Peak Power
Class D built-in amplifier powers the pair of 10” passive speakers.
Storage Compartment
Store cables and microphone(s) in the rear compartment of one speaker.
48V Phantom Power
48V Phantom Power supports condenser microphones for clean and accurate audio capture.
Portability
Quick to set up and take down, making travel simple. Enjoy it anywhere with no hassle.
Multiple Devices
Smooth Bluetooth pairing with TVs, computers, MacBooks, iPads, tablets, and mobile devices.
Performance
The ES-210MXBLU includes multiple mic and line inputs, allowing bands to connect everything through a single console. Its rugged construction withstands harsh conditions and frequent handling. Thanks to its compact and portable design, the ES-210MXBLU is easy to transport and set up quickly, making it ideal for outdoor events and performances.
Presentation
The ES-210MXBLU delivers strong, clear vocal projection in loud or large spaces, making it perfect for conferences, seminars, and outdoor rallies. It’s built for ease of use, with intuitive controls that let presenters adjust Volume, EQ, and Echo effect to match their preferences.
Ceremony
This system is ideal for capturing essential moments during your wedding ceremony or reception, allowing you to sound great even under pressure. It comes equipped with speaker stand mounts that enable you to mount each speaker on a tripod stand, ensuring optimal sound dispersion.
  • Active/Passive: Powered Mixer / Passive Speakers: This gem of a PA system rocks a powered mixer and passive speakers, making it one groovy setup. It's like a dynamic DJ duo: the powered mixer pumps up the jams, while the passive speakers smoothly deliver the sound. Ideal for professional events or just letting your hair down with live band performances.
  • Amplifier: Type Class D: Ever wondered what puts the 'pow' in power? It's our Class D amplifier! This little marvel is a sound maestro, making your speakers sing while being super energy efficient. It's the heart of our ES-MXBLU-ST system, giving life to your music.
  • LF Driver Size: 2 x 10”: Double 10" low-frequency drivers are here to bring the bass! These bad boys are the backbone of the sound, delivering deep, resonant lows that will shake the dance floor. It's like having two subwoofers disguised as ordinary speakers.
  • HF Drivers Size: 2 x 1”: Don't let their size fool you, these two 1” high-frequency drivers pack a punch. They ensure your sound is crystal clear, hitting those high notes flawlessly. Perfect for those power ballads or crisp cymbal hits.
  • Impedance: 4Ω (per speaker output): This system is like the yoga guru of sound systems, balancing impedance at a cool 4 Ohms per speaker. This means maximum efficiency and minimum distortion. Say hello to smoother, cleaner sounds at your events!
  • Total Power: 600W Peak: With 600W peak power, this PA system has got muscle! It's ready to handle any gig, any crowd, any time. All the power you need to get the party started, wrapped in one compact, portable package.
  • Inputs / Outputs: 4 x XLR Mic inputs w/ Phantom Power, 6 x 1/4” Line inputs, 1 x RCA Stereo input, 1 x 1/8” AUX Stereo input + 2 x 1/4" Powered Speaker Outputs, 2 x 1/4" Monitor Outputs, 1 x RCA Stereo Monitor Output : Say hello to connectivity heaven! This system is a DJ's dream with 4 XLR mic inputs (with Phantom Power), 6 ¼" line inputs, RCA and AUX stereo inputs, and more. Plus, it has powered speaker and monitor outputs, ensuring you're ready for any situation!
  • Media Player: FM Radio, Bluetooth, USB Drive, SD Card: Be the ultimate party starter with an all-in-one media player! FM radio, Bluetooth, USB drive, and SD card options let you choose the tunes and set the mood. Never miss a beat, and keep the party alive with this versatile, user-friendly system.
  • Bluetooth: V 5.0: Embrace wireless freedom with Bluetooth V 5.0! This advanced technology lets you stream music straight from your device, giving you the flexibility to play any song, anytime. Your portable PA system just got a whole lot cooler!
  • Frequency Response: 35Hz-20kHz: Experience a mind-blowing range of sound with a frequency response of 35Hz-20kHz. From deep bass to soaring highs, this system has got you covered. Your live events will sound better than ever, capturing every nuance and detail of your music.
  • Max Peak SPL @ 1 Meter: 96dB: Pump up the volume with a maximum peak SPL of 96dB at 1 meter! This powerful PA system delivers a loud, clear sound that's perfect for any event. Your guests will be amazed by the professional audio quality you can produce!
  • Signal Processing: Channel EQ & Echo Effect: Get creative with the built-in Channel EQ and Echo Effect! Tailor your sound to perfection, whether you're a DJ or live band. Enhance your performance and impress your audience with a professional-grade PA system that's both versatile and fun!
  • Enclosure Material: ABS impact-resistant nylon fiber / PP plastic: Fear not, this system is built to last with ABS impact-resistant nylon fiber and PP plastic! The durable, lightweight design makes it perfect for portable use. Say goodbye to wear and tear worries, and hello to years of reliable performance!
  • Mounting Options: Speaker Stand Mounts
BrandGemini
ModelES-210MXBLU
Part Number235-141
UPC747705001498
Unit of MeasurePairs
Weight46
ConfigurationFull-Range PA Speaker
Construction MaterialsHardshell / ABS Case
Speaker TypeBluetooth
Woofer Size10"
