  • Gemini AS-2115BT 15" Bluetooth Active Loudspeaker
CLEARANCE Gemini AS-2115BT 15" Bluetooth Active Loudspeaker
GeminiPart # 235-146
Model: AS-2115BT
With a 2000 Watt Class AB amplifier, the AS-2115BT provides powerful, room-filling sound in a lightweight package. Get perfect playback with a linear frequency response between 40Hz-20kHz for clear, full-range sound. The 15" low-frequency woofer and 2" piezo high-frequency compression driver deliver true and clear audio as it was meant to be heard.
  • 2000 watts of ultra clean, class AB power
  • Bluetooth® connectivity for wireless audio streaming
  • Built-in media player with USB and SD card inputs, plus FM radio
  • On-board two-channel mixer with individual gains
  • Rugged ABS impact-resistant nylon fiber cabinet for durability
  • Ergonomic handles for easy transport; flyable and stand mountable
CLEARANCE $249.95
MSRP: $399.95
Save $150.00 (38%)
2 In Stock
We'll send you an email when Gemini AS-2115BT 15" Bluetooth Active Loudspeaker is back in stock or available for preorder.
2000-watts Peak Power
Class-D amplifier delivers 2000 watts of peak output with a smooth 40Hz–20kHz response and a 15" woofer for powerful sound.
Bluetooth Connectivity
Supports wireless streaming over Bluetooth with 30+ ft range and stereo linking to another AS series speaker.
3-Channel Mixer
Features two analog channels, multiple input types, master EQ, and XLR mix out for flexible setup and control.
Rugged Build
Encased in a heavy-duty ABS nylon fiber cabinet built to endure demanding live performance environments.
Perfect Size
Standing 27.02" tall and weighing 30.09 lbs, it features ergonomic handles for easy transport while delivering high-quality sound, making it perfect for DJs, studios, and dance floors.
True Freedom, True Sound
True wireless sound delivers seamless connectivity across different settings, from fitness classes to dance floors, providing both freedom and clarity. Experience immersive surround sound without the need for cables.
Mount it Easily
With 1 3/8" tube diameter (35mm), elevate your sound effortlessly for events, performances, and more!
Clean Power, Clean Sound
Our Class-D amplifier drives the speakers with efficiency, delivering clear and refined audio that enhances your overall sound experience.
Fully Customize and Control
Featuring a 3-channel mixer with individual 1/4-inch and XLR inputs, dedicated gain controls, and an RCA input, this speaker offers broad compatibility with most entertainment and DJ systems.
  • Active/Passive: This speaker is "active", which means it comes with its own built-in amplifier. It's a self-contained unit, so there's no need for additional external amplifiers, making it a convenient choice for a PA speaker system.
  • Amplifier Type: Class AB: The Class AB amplifier in this speaker strikes a balance between pure efficiency and audio quality. It blends the clarity of Class A designs with the efficiency of Class B, delivering a sound that's detailed and powerful. For a DJ or sound enthusiast, this means the speaker provides consistently high-quality sound without wasting energy.
  • LF Driver Size: 15” Woofer with 2" high temperature voice coil: The 15" woofer, complemented by a 2" voice coil, is responsible for producing the lower frequency sounds in music. This size ensures the bass is prominent and powerful, reminiscent of Bluetooth speakers with subwoofers.
  • HF Driver Size: Pure titanium 1” high-frequency compression driver: This speaker boasts a 1-inch pure titanium high-frequency compression driver. Titanium ensures durability and clarity, producing sharp and clear high notes. It's the gemini in the system, ensuring every high note is perfectly rendered.
  • Total Power: 2000 Watts Peak: With an impressive 2000 Watts peak power, this speaker is more than capable of filling large spaces with sound. Ideal for DJ events or large gatherings, its power ensures that music remains undistorted, even at high volumes.
  • Inputs: 2 x ¼” and XLR Switchable Line/MIC Inputs 1/8” & RCA Aux Inputs: The multiple input options, including ¼” and XLR, provide versatility, allowing you to connect various sound sources. Whether it's a microphone, mixer, or a portable Bluetooth speaker source, this speaker accommodates.
  • Outputs: XLR Mix Output: The XLR Mix Output allows for connectivity to other sound systems, recording devices, or PA speakers pair, offering an expanded sound system setup.
  • Media Player: USB and SD Card playback (MP3, WAV) FM Radio: Beyond just a Bluetooth PA speaker, it boasts a media player that supports USB and SD Card playback. This feature ensures versatility in playing music, from playlists to FM Radio.
  • Bluetooth: Bluetooth Streaming with TWS Link: The built-in Bluetooth functionality allows for wireless music streaming. With the TWS Link feature, you can enjoy seamless connectivity, turning it into a central hub for Bluetooth powered speakers in a setup.
  • Frequency Response: 40HZ-20KHZ: A range of 40Hz to 20kHz means the speaker can reproduce a broad spectrum of sounds, from deep bass notes to sharp treble frequencies, ensuring every detail in a song is heard.
  • Max Peak SPL @ 1 Meter: 110dB: A peak sound level of 110dB indicates this speaker can get impressively loud, making it stand out in a lineup of powered PA speakers.
  • Signal Processing: Bass and Treble Controls: With bass and treble controls, you have the ability to customize the sound output, tailoring the music to your preferences, much like an experienced DJ fine-tuning a sound system.
  • Enclosure Material: ABS Plastic: Crafted from durable ABS Plastic, the speaker is designed to withstand regular use, ensuring longevity and reliability, akin to the sturdiness of outdoor PA speakers.
  • Mounting Options: Pole Mount with 35mm socket, 1 x M8 Fly Points: Offering versatile mounting solutions, you can choose to set it on a pole or use the fly points. This flexibility ensures optimal sound dispersion, whether in a cozy indoor setting or an expansive outdoor venue.
BrandGemini
ModelAS-2115BT
Part Number235-146
UPC747705007698
Weight36.98
Speaker TypeActive / Powered
