  • Galaxy Audio Neolite SW6.5 6.5" Neodymium Woofer 4 Ohm
CLEARANCE Galaxy Audio Neolite SW6.5 6.5" Neodymium Woofer 4 Ohm
Galaxy AudioPart # 245-2494
Model: SW6.5
Now available as a replacement speaker for the PA6S Hot Spot monitor, or as a component for new designs, the SW6.5 Neolite 6.5" woofer features a 3.4 ounce Neodymium magnet mounted on an ABS plastic basket. The high excursion cone and thick surround allow for low frequencies to be produced cleanly.
  • Neodymium magnet structure
  • Lightweight ABS frame
  • Front or rear mounting
  • Ferrofluid cooled for increased power handling
Ciare CMR160 6.5" Full-Range Driver 4 Ohm
Price: $92.18Part # 293-108
We'll send you an email when Galaxy Audio Neolite SW6.5 6.5" Neodymium Woofer 4 Ohm is back in stock or available for preorder.
Galaxy Audio is happy to announce that the Neolite 6.5" woofer is available for custom applications or as an upgrade to existing designs. Used in the wildly popular PA6S Hot Spot powered personal monitor system, the SW6.5 is also an excellent candidate for midrange duty, or as a dedicated woofer in small 2-way systems. With power handling capability of up to 155 watts, 50 - 8kHz frequency range, and ferrofluid cooling, the SW6.5 can hold its own, even under the most demanding conditions.
BrandGalaxy Audio
ModelSW6.5
Part Number245-2494
UPC691281000744
Weight1.65
Nominal Diameter6-1/2"
Power Handling (RMS)75 Watts
Power Handling (MAX)155 Watts
Frequency Response50 to 8,000Hz
Sensitivity88dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)45.5Hz
Mechanical Q (Qms)3.05
Electromagnetic Q (Qes)0.29
Total Q (Qts)0.27
Compliance Equivalent Volume (Vas)0.73ft³
Cone MaterialPoly Composite
Magnet MaterialNeodymium
Overall Outside Diameter6.375"
Baffle Cutout Diameter5.75"
Depth3.125"
Sealed Volume0.15ft³
Sealed F3135.1Hz
Vented Volume0.5ft³
Vented F358.1Hz
