  • Fourjay 440-8 Thundering Mini Horn Speaker
Fourjay IndustriesPart # 300-066
Model: 440-8
Designed for good speech intelligibility, the 440-8 Thundering Mini is ideal for two-way communications on trucks, heavy equipment, boats, helicopters, etc. and provides excellent sensitivity as a microphone in talk-back systems.
Fourjay 306-8 Little Big Horn 8 Ohm
Price: $65.22Part # 300-067
See all items in PA Horn Speakers
Your Price: $92.89
MSRP: $139.99
Save $47.10 (34%)
We'll send you an email when Fourjay 440-8 Thundering Mini Horn Speaker is back in stock or available for preorder.
Order in the next 3 hr 15 min to ship today. Details
Designed for good speech intelligibility, the 440-8 Thundering Mini is ideal for two-way communications on trucks, heavy equipment, boats, helicopters, etc. and provides excellent sensitivity as a microphone in talk-back systems. The 440-8 is a small re-entrant horn package with a powerful, efficient and durable compression driver which converts security system square wave torture into a high output distress signal. A heat sink coupled to the driver dissipates heat to maintain efficiency and endurance. Weather and corrosion resistant construction uses stainless steel fasteners and the plating on the driver meets a 96-hour salt spray test, while the horn itself is constructed of impact and UV resistant ABS. The adjustable mounting base will attach to a 3" electrical box. Flange holes allow for recessed or concealed mounting. The 440-8 comes with a 30" black jacketed cable for fast "hard wiring" and good weatherability. Tan horn with brown diffuser/inner horn. Fourjay model 440-8. Made in the USA.
Specifications: • Rated input: 8 ohms • Power handling: 40 watts continuous duty • Frequency range: 700-6,500 Hz • Sensitivity: 107 dB.
BrandFourjay Industries
Model440-8
Part Number300-066
UPC844632007330
Weight3.4848
Speaker TypePA Horn Speaker
