  • Fourjay 306-8 Little Big Horn 8 Ohm
Fourjay IndustriesPart # 300-067
Model: 306-8
Designed for paging and music in moderately noisy environments, the Little Big Horn provides pleasing voice projection and high speech intelligibility. 8 ohm impedance.
Fourjay 440-8 Thundering Mini Horn Speaker
Price: $92.89Part # 300-066
5" Indoor / Outdoor Horn Speaker White
Price: $7.89Part # 300-050
See all items in PA Horn Speakers
Your Price: $65.22
Save $29.77 (31%)
We'll send you an email when Fourjay 306-8 Little Big Horn 8 Ohm is back in stock or available for preorder.
Order in the next 0 hr 42 min to ship today. Details
Designed for paging and music in moderately noisy environments, the Little Big Horn provides pleasing voice projection and high speech intelligibility. Constructed of impact & UV resistant ABS and stainless steel fasteners, it is weather and corrosion resistant while the reflex driver uses a moisture resistant diaphragm. The adjustable mounting base will attach to a 3" electrical box or it may be recess mounted; the hole locations are provided on the flange. Tan in color. Made in the USA.
Specifications: • Rated input: 8 ohms • Power tap: 6 watts • Frequency range: 400-5,000 Hz • Sensitivity: 97 dB • Mfg. #306-8 • Dimensions: 5-1/2" W x 5-1/2" H x 4-1/2" D (excluding mounting base).
BrandFourjay Industries
Model306-8
Part Number300-067
UPC844632007347
Weight2.0592
Speaker TypePA Horn Speaker
