  • Flip Up Stage Box with Eight XLR Female Jacks
CLEARANCE Flip Up Stage Box with Eight XLR Female Jacks
3 Questions, 5 Answers or
Part #240-308
Part #240-308
Our rugged flip-up pocket boxes clean up the cable clutter found on typical stages, studios, houses of worship, classrooms, or boardrooms. This floor box features eight female XLR jacks.
  • 12 gauge steel construction stands up to hard use
  • Tapered carpet trim ring reduces snags and trip hazards
  • Customizable side panels for maximum flexibility
  • Removable bottom panel facilitates installation
  • Cable slots in door help cables lay flat
Pocket boxes offer a convenient point of access for cables while protecting the connectors from unintentional damage. Our flip-up boxes are made from 12 gauge steel to stand up to the rigors of life on the big stage. Durable construction and built-in adaptability make these boxes suited perfectly for use in-wall, in a desk or lectern, or just about anywhere convenient cable access is desired. Slanted connector panels provide easier connector access, while 1-1/4" long cable slots in the cover allow it to remain closed while in use. The box's tapered carpet ring provides a finished appearance for any installation.
Each box features removable and customizable side panels, pre-loaded with connectors or pre-punched to accommodate standard type "D" connectors. Removable bottom panels can be drilled or punched to meet your installation's unique needs. Two box styles are available.
Dimensions: • Internal pocket size: 9" L x 4-3/4" W x 2-3/8" D • Overall external dimensions: 13-7/8" L x 8" W x 3" D.
Part Number240-308
UPC848864017891
Weight6.3
