  • Ferrofluid 650uL General Purpose for 2" Diameter V.C.
Ferrotec Corp USAPart # 340-544
Ferrofluid improves the performance of high frequency and midrange drivers. It works by damping the impedance at resonance to effectively lower distortion, smooth frequency response, and increase thermal power handling.
  • Great for retrofit/replacement or new applications
  • Damps impedance at resonance
  • Reduces distortion
  • Conducts heat away from voice coil
  • Increases power handling capacity
  • Comes complete with cleaning strips and instructions
  • Sized to fit approximate voice coil diameters
Your Price: $9.99
MSRP: $14.99
Save $5.00 (33%)
Quantity:Qty: 1-3 $9.99/ea
Quantity:Qty: 4+ $8.99/ea
We'll send you an email when Ferrofluid 650uL General Purpose for 2" Diameter V.C. is back in stock or available for preorder.
Order in the next 9 hr 12 min to ship today. Details
Ferrofluid improves the performance of high frequency and midrange drivers. It works by damping the impedance at resonance to effectively lower distortion, smooth frequency response, and increase thermal power handling. It should be used to replenish drivers treated previously with ferrofluid. With care, it can also upgrade most drivers that have never contained ferrofluid.
The kits listed are approximate fill quantities relative to approximate voice coil diameters. In general, the air gap should be 75% filled prior to inserting a voice coil diaphragm assembly. The kit contains synthetic ester-based ferrofluids and in most cases should not pose any adhesive incompatibility. It is recommended that this is confirmed by contacting the driver manufacturer prior to usage. Adding ferrofluid to a driver not intended for it will, in most cases, void the original manufacturer's warranty.
Included in kit: A ferrofluid packet, absorbent paper strips for removing old ferrofluid, detailed instructions, and material safety data sheet.
BrandFerrotec Corp USA
Part Number340-544
UPC844632086311
Weight0.1
