NEW FaitalPRO HF206 Neodymium Compression Horn Driver 16 Ohm 4-Bolt
The HF206 is a 2″ throat-diameter compression driver built for professional horn-loaded systems that demand clarity, high output, and long-term reliability.
- 65 mm (2.56 in) voice coil diameter with aluminum winding on Kapton former
- Frequency range of 500Hz–18 kHz for full high-frequency coverage
- 30° conical exit angle with recessed phase plug
- Neodymium slug magnet with 1.7 T magnetic flux density for strong motor drive
- Made in Italy
We'll send you an email when FaitalPRO HF206 Neodymium Compression Horn Driver 16 Ohm 4-Bolt is back in stock or available for preorder.
