  • FaitalPRO HF109 Compression Horn Driver 8 Ohm 2/3-Bolt
NEW FaitalPRO HF109 Compression Horn Driver 8 Ohm 2/3-Bolt
FaitalPROPart # 294-1075
Model: HF109
The HF109 is a 1″ compression driver built for professional audio systems where high efficiency and clear high-frequency response matter. With a rated power handling of 60 W AES and a sensitivity of 108 dB, it provides crisp, articulate highs with minimal amplifier demand.
  • 1″ throat diameter
  • 1.73" (44 mm) voice coil with aluminum winding on a Kapton former
  • Ferrite ring magnet with 1.8 T flux density for strong motor drive
  • Frequency range from 1 kHz to 20 kHz for full high-end coverage
  • Minimum recommended crossover frequency of 1.3 kHz
  • Made in Italy
NEW $200.00
We'll send you an email when FaitalPRO HF109 Compression Horn Driver 8 Ohm 2/3-Bolt is back in stock or available for preorder.
The HF109 offers high-output highs thanks to its 108 dB sensitivity and 60 W AES rating, meaning it achieves strong SPL without needing an oversized amplifier. A 1.73" (44 mm) diameter aluminum voice coil mounted on a Kapton former manages thermal stress while staying lightweight for quick response. The ferrite ring magnet structure with a flux density of 1.8 T delivers robust motor control, providing clarity and accuracy especially in horn-loaded configurations. With a frequency range of 1 kHz to 20 kHz and a minimum crossover point at 1.3 kHz, this driver covers standard high-frequency duties with ease. Its compact dimensions allow it to fit into tight horn or compression driver assemblies while supporting professional-grade performance in installations and tour-grade systems.
BrandFaitalPRO
ModelHF109
Part Number294-1075
UPC848864081809
Weight5.1
Exit Diameter1"
Mounting Type3/4-Bolt
Power Handling (RMS)60 Watts
