  • FaitalPRO 15FH520 15" Neodymium Professional Subwoofer 8 Ohm
FaitalPROPart # 294-1063
Model: 15FH520
The FaitalPRO 15FH520 is a 15" low‑frequency driver engineered for high‑output bass systems that require both impact and precision. Its neodymium motor structure and high‑efficiency design deliver strong output and dependable performance.
  • 600 W AES power rating with 1,200 W program capability
  • 98 dB sensitivity delivers strong sound pressure with efficient amplification
  • 3" copper voice coil on fiberglass former ensures thermal stability
  • Neodymium magnet system with 1.1 T flux density for high motor force
  • Wide 40–4,000 Hz frequency span covers deep bass and upper low‑midrange
  • ±8.75 mm Xmax and 16 mm peak‑to‑peak excursion give ample dynamic travel
  • Made in Italy
FaitalPRO 15FH500 15" Neodymium Professional Subwoofer 8 Ohm
Price: $434.00Part # 294-1060
Your Price: $484.00
We'll send you an email when FaitalPRO 15FH520 15" Neodymium Professional Subwoofer 8 Ohm is back in stock or available for preorder.
With its 600 W AES rating and 98 dB sensitivity, the 15FH520 achieves impressive output without the need for oversized amplification. The 3" copper voice coil wound on a fiberglass former provides reliable thermal management under sustained use. A robust neodymium motor structure with a 1.1 Tesla flux density ensures strong control and high efficiency. The wide 40–4,000 Hz frequency range and the ±8.75 mm linear excursion (with a 16 mm damage limit) support both deep bass and rapid mid‑transitions in high‑demand systems. The aluminum frame and demodulating ring help reduce mass and distortion, making this driver ideal for professional sound systems requiring high performance and efficient bass reproduction.
BrandFaitalPRO
Model15FH520
Part Number294-1063
UPC848864081731
Weight10.8
Nominal Diameter15"
Bolt Circle Diameter14.72
Power Handling (RMS)600 Watts
Impedance8Ω
Frequency Response40 to 4000Hz
Sensitivity98dB 2.83V/1m
Voice Coil Diameter3"
Resonant Frequency (Fs)36Hz
DC Resistance (Re)5.6Ω
Voice Coil Inductance (Le)0.89mH
Mechanical Q (Qms)10.1
Electromagnetic Q (Qes)0.41
Total Q (Qts)0.39
Compliance Equivalent Volume (Vas)6.59ft³
Mechanical Compliance of Suspension (Cms)0.19mm/N
BL Product (BL)18.4T·m
Diaphragm Mass Inc. Airload (Mms)105g
Maximum Linear Excursion (Xmax)8.75mm
Surface Area of Cone (Sd)847cm²
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter15.47"
Baffle Cutout Diameter14.02"
Depth7.14"
Sealed Volume1.191ft³
Sealed F384.19Hz
Vented Volume4.974ft³
Vented F339.22Hz
