  • FaitalPRO 15FH500 15" Neodymium Professional Subwoofer 16 Ohm
NEW FaitalPRO 15FH500 15" Neodymium Professional Subwoofer 16 Ohm
FaitalPROPart # 294-1061
Model: 15FH500
The 15FH500 is a 15″ (380 mm) professional low‑frequency loudspeaker designed for use in demanding audio systems. With its high AES rating and neodymium motor, it is suitable for medium–high output bass applications where fidelity and efficiency matter.
  • 500 W AES power handling (1,000 W maximum) for sustained output
  • 97 dB sensitivity ensures strong output with moderate amplifier power
  • Frequency range 35 Hz – 3,150 Hz covering deep bass to upper low‑mid frequencies
  • 3″ (77 mm) voice coil on fiberglass former for improved thermal stability
  • Neodymium magnet structure with 1.2 T flux density and aluminum basket for lightweight and rigidity
  • Xmax of 9.25 mm and damage limit at 16 mm excursion for robust performance under load
  • Made in Italy
NEW $413.00
We'll send you an email when FaitalPRO 15FH500 15" Neodymium Professional Subwoofer 16 Ohm is back in stock or available for preorder.
The 15FH500 combines high power handling and high sensitivity to deliver significant bass output without requiring excess amplifier power. Its neodymium magnet system and 1.2 T flux density provide strong motor force in a compact design. The 3″ voice coil mounted on a fiberglass former resists thermal stress during extended use and helps maintain linearity. With a broad 35 Hz to 3,150 Hz frequency range, this driver covers deep bass and low‑mid frequencies, making it suitable for systems that demand both impact and clarity. The excursion capability (±9.25 mm Xmax, up to 16 mm before damage) offers generous headroom for dynamic signals. A rigid aluminum basket keeps mechanical resonance under control. Overall, the 15FH500 is a strong choice for professional sound systems where high output, durability, and efficient bass reproduction are required.
BrandFaitalPRO
Model15FH500
Part Number294-1061
UPC848864081663
Weight10.15
Nominal Diameter15"
Bolt Circle Diameter14.72
Power Handling (RMS)500 Watts
Impedance16Ω
Frequency Response35 to 3150Hz
Sensitivity97dB 2.83V/1m
Voice Coil Diameter3"
Resonant Frequency (Fs)35Hz
DC Resistance (Re)12.7Ω
Voice Coil Inductance (Le)2mH
Mechanical Q (Qms)13.2
Electromagnetic Q (Qes)0.47
Total Q (Qts)0.45
Compliance Equivalent Volume (Vas)7.67ft³
Mechanical Compliance of Suspension (Cms)0.22mm/N
BL Product (BL)23.8T·m
Diaphragm Mass Inc. Airload (Mms)95.4g
Maximum Linear Excursion (Xmax)9.25mm
Surface Area of Cone (Sd)847cm²
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter15.47"
Baffle Cutout Diameter14.02"
Depth7.14"
Sealed Volume1.98ft³
Sealed F371.12Hz
Vented Volume9.316ft³
Vented F330.37Hz
