  • FaitalPRO 12PR300 12" Neodymium Professional Woofer 8 Ohm
FaitalPROPart # 294-1241
Model: 12PR300
Choose FaitalPRO's 12" 12PR300 woofer to replace or upgrade the woofer in your speaker cabinet. A flat frequency response to 5,000 Hz and high sensitivity of 99 dB (1W/1m) allows it to match well with nearly any horn driver.
  • Lightweight design weighs just over 5-1/2 pounds
  • 99 dB sensitivity due to high-energy neo motor
  • Durable cast-aluminum frame
  • Ultra-linear frequency response
  • Made in Italy
Your Price: $316.00
Only 2 In Stock
We'll send you an email when FaitalPRO 12PR300 12" Neodymium Professional Woofer 8 Ohm is back in stock or available for preorder.
Order in the next 12 hr 33 min to ship today. Details
With high sensitivity and a ruler-flat frequency response from 50 Hz to 5,000 Hz, FaitalPRO's 12PR300 12" woofer is perfect for replacing and upgrading tired, worn-out woofers in small to large-sized, vented two-way speakers. The 12PR300 is a great choice for live sound and high output home audio speakers.
An eight-spoke, cast-aluminum frame adds structural integrity, while the treated paper cone and polycotton M-Roll surround can withstand years of constant use. The 300 watt RMS power handling rating is made possible by the use of a 2.5" voice coil on a glass fiber former. A neodymium slug motor keeps weight low, just over 5-1/2 pounds. Made in Italy.
BrandFaitalPRO
Model12PR300
Part Number294-1241
UPC848864008448
Weight7.45
Nominal Diameter12"
Bolt Circle Diameter11.75
Power Handling (RMS)300 Watts
Power Handling (MAX)600 Watts
Impedance8Ω
Frequency Response50 to 5,000Hz
Sensitivity99dB 2.83V/1m
Voice Coil Diameter2.5"
Resonant Frequency (Fs)50Hz
DC Resistance (Re)5.4Ω
Voice Coil Inductance (Le)0.42mH
Mechanical Q (Qms)9.92
Electromagnetic Q (Qes)0.37
Total Q (Qts)0.36
Compliance Equivalent Volume (Vas)2.8ft³
Mechanical Compliance of Suspension (Cms)0.23mm/N
BL Product (BL)14.1T·m
Diaphragm Mass Inc. Airload (Mms)43.4g
Maximum Linear Excursion (Xmax)4.92mm
Surface Area of Cone (Sd)489cm²
Cone MaterialTreated Paper
Surround MaterialCloth
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter12.41"
Baffle Cutout Diameter11.06"
Depth5.54"
Sealed Volume0.8ft³
Sealed F3109.9Hz
Vented Volume1.8ft³
Vented F362.4Hz
