  • FaitalPRO 10PR300 10" Neodymium Professional Woofer 8 Ohm
FaitalPROPart # 294-1203
Model: 10PR300
Choose FaitalPRO's 10" 10PR300 woofer to replace or upgrade the woofer in your speaker cabinet. A flat frequency response to 5,000 Hz and high sensitivity of 98 dB (1W/1m) allows it to match well with nearly any horn driver.
  • Lightweight design weighs just over 9 pounds
  • 98 dB sensitivity due to high-energy neo motor
  • Durable cast-aluminum frame
  • Ultra-linear frequency response to 5,000 Hz
  • Made in Italy
Your Price: $305.00
Only 1 In Stock More due on 9/18/2026
We'll send you an email when FaitalPRO 10PR300 10" Neodymium Professional Woofer 8 Ohm is back in stock or available for preorder.
Order in the next 1 hr 9 min to ship today. Details
With high sensitivity and a ruler-flat frequency response from 60 Hz to 5,000 Hz, FaitalPRO's 10PR300 10" woofer is perfect for replacing and upgrading tired, worn-out woofers in small to large-sized, vented two-way speakers. The 10PR300 is a great choice for live sound and high output home audio speakers.
An eight-spoke, cast-aluminum frame adds structural integrity, while the treated paper cone and polycotton M-Roll surround can stands up to years of constant use. The 300 watt RMS power handling rating is made possible by the use of a 2.5" voice coil on a glass fiber former. A neodymium slug motor keeps weight low, just over 9 pounds. Made in Italy.
BrandFaitalPRO
Model10PR300
Part Number294-1203
UPC848864008578
Weight6.25
Nominal Diameter10"
Bolt Circle Diameter9.69
Power Handling (RMS)300 Watts
Power Handling (MAX)600 Watts
Frequency Response60 to 5,000Hz
Sensitivity98dB 2.83V/1m
Voice Coil Diameter2.5"
Resonant Frequency (Fs)60Hz
DC Resistance (Re)5.4Ω
Voice Coil Inductance (Le)0.6mH
Mechanical Q (Qms)5.8
Electromagnetic Q (Qes)0.29
Total Q (Qts)0.27
Compliance Equivalent Volume (Vas)1.3ft³
Mechanical Compliance of Suspension (Cms)0.25mm/N
BL Product (BL)14.1T·m
Diaphragm Mass Inc. Airload (Mms)28.2g
Maximum Linear Excursion (Xmax)4.92mm
Surface Area of Cone (Sd)322cm²
Cone MaterialTreated Paper
Surround MaterialCloth
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter10.28"
Baffle Cutout Diameter9.06"
Depth4.54"
Vented Volume0.8ft³
Vented F362.7Hz
