Harrison Labs FMOD Inline Crossover Pair 50 Hz High Pass RCA
We'll send you an email when Harrison Labs FMOD Inline Crossover Pair 50 Hz High Pass RCA is back in stock or available for preorder.
Extra 15% off Outlet Center items with code STOCK15. SHOP NOW
Ends 10/26 at 11:59pm ET.
What is an FMOD™? The FMOD™ is an active crossover simulator. It is better than a much more expensive electronic crossover that requires power to operate. FMODs™ are packaged in pairs and can be combined with other FMODs™ to obtain bandpass ranges or with other types of crossovers to change the slope and crossover frequency point. FMODs™ feature a 12 dB per octave crossover slope and are compatible with all RCA type input amps...simply place the FMOD™ in-line with the patch cable running between the source (head unit) and the amplifier. 24kt gold over brass construction, 10 volts maximum RMS input. One-year manfacturer warranty. Made in the U.S.A.
Product Details | |
| Brand | Harrison Labs |
| Part Number | 266-270 |
| UPC | 844632053191 |
| Unit of Measure | Pairs |
| Weight | 0.0908 |
Product Specifications | |
| Configuration | Inline Line Level |
| Crossover Type | High Pass |
