  • Epique High Resolution Ceramic Dome Tweeter 30mm 4 Ohm Matched Pair
EPIQUE by Dayton AudioPart # 275-502
Model: EC30MP-4
The Dayton Audio Epique EC30-4 Ceramic Dome Tweeter delivers ultra-clear, high-resolution sound with precision engineering. Its vapor-deposited ceramic-coated aluminum dome ensures piston-like accuracy while eliminating common breakup distortion, extending smooth response beyond 40 kHz. With advanced rear-wave control, low-distortion design, and a durable aluminum faceplate, the EC30-4 offers unmatched transparency and reliability for premium home audio, studio monitors, and custom loudspeakers.
  • High-Resolution Ceramic Dome – 30mm aluminum dome reinforced with vapor-deposited ceramic coating for stiffness and accurate piston performance
  • Extended Frequency Response – Smooth, distortion-free sound extending well past 40 kHz, ideal for high-resolution audio systems
  • Rear-Wave Dissipation – Precision-engineered back plate and damping materials eliminate internal resonances for maximum transparency
  • Low Distortion Design – Copper cap and Kapton former reduce inductance and distortion, enhancing clarity and detail
  • Premium Build Quality – Oversized Y35 magnet delivers power and control, while a treated cloth surround ensures long-term performance
  • Durable & Stylish Construction – 3.6mm thick aluminum faceplate with honeycomb mesh protective grill for added strength and protection
  • Versatile Applications – Perfect for high-end home audio, studio monitors, and custom loudspeaker designs seeking uncompromised treble performance
Epique High Resolution Ceramic Dome Tweeter 30mm 4 Ohm EC30-4
Price: $69.98Part # 275-500
See all items in Tweeters
Your Price: $149.98
Save $190.01 (56%)
We'll send you an email when Epique High Resolution Ceramic Dome Tweeter 30mm 4 Ohm Matched Pair is back in stock or available for preorder.
The Dayton Audio Epique EC30-4 Ceramic Dome Tweeter sets a new benchmark for high-resolution audio performance. Built to last, it is designed with meticulous precision and crafted from premium materials to ensure both exceptional sound and long-term reliability. The EC30-4 combines substance with style, featuring a rugged 3.6mm aluminum faceplate and a honeycomb mesh protective grill that deliver durability without compromising elegance. Its advanced ceramic dome construction brings out the finest details in music reproduction, producing crystal-clear highs and unmatched transparency that remain consistent across listening environments.
Engineered for Transparency
At the heart of its design is a 30mm aluminum dome, reinforced with a vapor-deposited ceramic coating. This advanced construction delivers true piston-like motion, eliminating the common breakup modes found in standard aluminum domes and extending usable bandwidth well beyond 40 kHz—ideal for today’s high-resolution audio formats. A lightweight Kapton former further enhances performance by increasing power handling while reducing moving mass, ensuring clean, dynamic response even at demanding output levels.
To further enhance performance, the EC30-4 employs a precision-engineered back cup with strategically placed damping materials that effectively dissipate the rear wave, reducing internal resonances and preserving clarity. A copper cap and Kapton former minimize inductance and distortion, allowing for smoother, more detailed playback across the frequency spectrum. Built with an oversized Y35 magnet and treated low-loss cloth surround, the tweeter offers both power and long-term reliability for demanding audio applications.
Built for the Long-Haul
Tipping the scales at nearly 3 lbs, the EC30-4 makes a bold statement in both performance and design. Its rugged 3.6mm aluminum faceplate and sleek honeycomb mesh grill not only ensure rock-solid durability but also exude refined elegance. Perfect for high-end home audio, studio monitoring, or custom speaker builds, this tweeter delivers shimmering treble with uncompromising clarity—engineered for those who refuse to settle for anything less than extraordinary sound.
The EC30-4 delivers an impressively flat frequency response from 800 Hz all the way to 20 kHz, ensuring smooth, natural reproduction across the critical midrange and treble. Its advanced ceramic dome design effectively suppresses resonance, keeping any potential breakup modes well controlled and pushed far beyond the limits of human hearing—remaining tamed below 40 kHz. This extended stability not only preserves accuracy in the audible spectrum but also enhances transient response and overall clarity, making the EC30-4 an ideal choice for applications where precision and detail are paramount.
The EC30-4’s distortion performance reflects the strength of its motor design and careful attention to inductance control. A copper cap on the pole piece works to linearize the magnetic field and reduce inductance modulation, keeping harmonic distortion exceptionally low even as output increases. Combined with an extremely powerful motor structure built around an oversized Y35 magnet, the tweeter maintains tight control over diaphragm motion, preventing unwanted artifacts and preserving fine detail. The result is a smooth, highly resolved top end where second and third harmonic distortion remain well suppressed across the usable bandwidth, allowing subtle nuances and spatial cues to come through with clarity and precision.
The EC30-4 is built for those who want to extract every last bit of accuracy and detail from their system. Its low distortion, powerful motor, and extended bandwidth make it a natural fit for premium 2-way and 3-way designs where clarity, dynamics, and precision take center stage. From compact bookshelf builds to full-scale reference systems, it delivers a clean, effortless top end that reveals nuance without harshness or fatigue. When performance and refinement are non-negotiable, the EC30-4 becomes an obvious choice.
Key Specifications:
  • Impedance: 4 Ohm
  • Fs: 698.8 Hz
  • SPL: 92 dB
  • Frequency Response: 1,500 - 40,000 Hz
  • Power Handling: 80W RMS
BrandEPIQUE by Dayton Audio
ModelEC30MP-4
Part Number275-502
UPC848864079912
Unit of MeasurePairs
Weight6.05
Bolt Circle Diameter4.5
Power Handling (RMS)80 Watts
Power Handling (MAX)160 Watts
Impedance4Ω
Frequency Response1,500 to 40,000Hz
Sensitivity92dB 2.83V/1m
Voice Coil Diameter1.125"
Resonant Frequency (Fs)700Hz
DC Resistance (Re)4.03Ω
Mechanical Q (Qms)3.376
Electromagnetic Q (Qes)1.163
Surround MaterialCloth
Overall Outside Diameter5.1"
Baffle Cutout Diameter4"
Depth2"
# Mounting Holes6
